In the assembly drawing, a ModelGeometry.ContainingOccurrence error occurs.
BenAtok
BenAtok
I'm trying to write a program that checks which parts are not ballooned in the BOM and then goes through all the drawing curves in the assembly drawing to balloon them. However, an error occurs when attempting to get ModelGeometry from DrawingCurve (line 38). Can someone help me resolve this issue?
Public Sub CheckPartsList()
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    Dim oActiveSheet As Sheet
    Set oActiveSheet = oDrawDoc.ActiveSheet
    Dim oPartsList As PartsList
    Set oPartsList = oActiveSheet.PartsLists(1)
    Dim oPartslistRow As PartsListRow
    Dim lstOfComponents As String
    For Each oPartslistRow In oPartsList.PartsListRows
        If oPartslistRow.Ballooned = False Then
            Dim ItemNumber As String
            ItemNumber = oPartslistRow.Item(5).Value
            lstOfComponents = ItemNumber
    Next
    Dim oDrawView As DrawingView
    Set oDrawView = oActiveSheet.DrawingViews.Item(1)
    Dim oDrawCurves As DrawingCurvesEnumerator
    Set oDrawCurves = oDrawView.DrawingCurves
    Dim oDrawCurve As DrawingCurve
    Dim oCurveModelGeometry As Object
    Dim oCurveContainingOccurence As Object
    Dim PartNameFromCurve
    For Each oDrawCurve In oDrawCurves
        Set oCurveModelGeometry = oDrawCurve.ModelGeometry
        '-------------delet part name from ":"
        Set oCurveContainingOccurence = oCurveModelGeometry.ContainingOccurrence
        PartNameFromCurve = oCurveContainingOccurence.Name
        colonPosition = InStr(PartNameFromCurve, ":")
        If colonPosition > 0 Then
            ConfiguredPartNameFromCurve = Left(PartNameFromCurve, colonPosition - 1)
        Else
            ConfiguredPartNameFromCurve = PartNameFromCurve
        '-----------compare part name from BOM and Drawingcurve
        If ConfiguredPartNameFromCurve = lstOfComponents Then
            MsgBox (PartNameFromCurve)
            Exit For
    Next
    Stop
End Sub
jjstr8
It looks like DrawingCurves is also returning Interference Edges.  They don't belong to a model, hence the error.  Add a check for oDrawCurve.ProjectedCurveType <> kUnknownCurve2d before getting ModelGeometry.
Michael.Navara
Iteration over drawing curves and check which model belongs to is highway to hell.
Much better is to get component from PartsListRow and obtain its drawing curves. The sample below show you just "HOW TO" . It is not full implementation. It just selects one of many drawing curves which belongs to un-balloned component.
    Dim asm As AssemblyDocument
    Set asm = oPartsList.ReferencedDocumentDescriptor.ReferencedDocument
        If Not oPartslistRow.Ballooned Then
            Dim drawingBomRow As drawingBomRow
            Set drawingBomRow = oPartslistRow.ReferencedRows(1)
            Dim bomRow As bomRow
            Set bomRow = drawingBomRow.bomRow
            Dim compDef As ComponentDefinition
            Set compDef = bomRow.ComponentDefinitions(1)
            Dim occurrences As ComponentOccurrencesEnumerator
            Set occurrences = asm.ComponentDefinition.occurrences.AllReferencedOccurrences(compDef)
            Dim drawingCurvesEnumerator As drawingCurvesEnumerator
            Set drawingCurvesEnumerator = oActiveSheet.DrawingViews(1).DrawingCurves(occurrences(1))
            Call oDrawDoc.SelectSet.Clear
            Call oDrawDoc.SelectSet.Select(drawingCurvesEnumerator(1).Segments(1))
            MsgBox ("Continue")
    Next
End Sub
BenAtok
Thank you, it works perfectly. Maybe you can tell me more about why it's bad to iterate over drawing curves and check for which model it belongs? Is the process too slow or can too many errors accrue?
Michael.Navara
There are several reasons
1. Performance. I worked on drawings with ten-thousands of drawing curves. Iteration over this collection spends a lot of time.
2. Drawing curves are not persistent objects. Sometimes it can be replaced with the new drawing curve for some reason. (Historical experience, it is hard to prepare working dataset but it happens sometimes)
