Improve Multi Faces color overwriting
fsanchou
fsanchou
Manually If I double-click on a face to select also tangented faces, overwriting take few seconds (less 2 seconds) for 20 faces.
With code below, this operation take more 16 seconds for the sames 20 faces!
Which commands is use by manual method or how improve it?
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
Dim oFace As Face
Try
	oFace = oPartDoc.SelectSet.Item(1)
Catch
	Exit Sub
End Try
Dim oColorAsset As Asset
Try
	oColorAsset = oPartDoc.AppearanceAssets.Item("Or")
Catch
	Exit Sub
End Try
oFace.Appearance = oColorAsset
Dim oTangentedface As Face
For Each oTangentedface In oFace.TangentiallyConnectedFaces
	oTangentedface.Appearance = oColorAsset
Next
YuhanZhang
Can you attach a data to reproduce the problem? Don't attach confidential data.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
fsanchou
Hi @YuhanZhang,
As I can't send confidential data, I wanted to create a sample data sample.
And of course, in sample data, code works correctly ... 😉
So by exploring my data, I found problem comes from flatpattern update!
By adding code bellow, that works correctly:
oPartDoc.FlatPatternSettings.DeferUpdate = True
'..... execution
oPartDoc.FlatPatternSettings.DeferUpdate = False
YuhanZhang
Glad to hear you solved it by yourself:).
Rocky Zhang
Inventor API PD
Autodesk, Inc.
