Import XML Options - Batch file
Good afternoon. Making things short, is there a method to import both the ilogic XML file (iLogicOptions.xml) and the Ribbon Customization XML through a batch file? I know you can use
"C:\Program Files\Autodesk\Inventor 2019\Bin\Inventor.exe" /IMPORTCUSTOMIZATIONS="
for certain imports. But what about the ilogic  and Ribbon XML files specifically? I am looking to import these via batch file for new and current users when doing updates.
Thank you,
JelteDeJong
as far as i know ther are none extra startup options for those settings. But all those options are saved in xml files that you can copy to the correct location.
The ilogic options :
%appdata%\Autodesk\Inventor 2020\iLogicPreferences\iLogicOptions.xml
Ribbon XML files:
%appdata%\Autodesk\Inventor 2020\InventorCustomization.xml
Jelte de Jong
Blog: hjalte.nl - github.com
