Import stp file
Import stp file
Import stp file
Hi
this is my request:
- open an STP file in Inventor
- save as .ipt file inside a defined folder
My problem:
- I don't get i how to set the final folder for saving;
- is it possible to make all this in a silent way, because right now doesn't work, maybe via apprencticve server?
Paolo
this is my code
// call Inventor application
          Inventor.Application InvApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application") as Inventor.Application;
          InvApp.SilentOperation = true;
          // GET STP Addin
          string stpId = "{90AF7F40-0C01-11D5-8E83-0010B541CD80}";
          TranslatorAddIn StpAddin = InvApp.ApplicationAddIns.ItemById[stpId] as TranslatorAddIn;
          TransientObjects tObjs = InvApp.TransientObjects as TransientObjects;
          DataMedium file = tObjs.CreateDataMedium();
          file.FileName = fileName;
          TranslationContext context = tObjs.CreateTranslationContext();
          context.Type = Inventor.IOMechanismEnum.kDataDropIOMechanism;
          NameValueMap options = tObjs.CreateNameValueMap();
          options.Value["SaveComponentDuringLoad"] = true;
          options.Value["SaveLocationIndex"] = 0;
          options.Value["ComponentDestFolder"] = "";
          options.Value["ImportSolid"] = true;
          options.Value["ImportSurface"] = true;
          options.Value["ImportWire"] = false;
          options.Value["ImportPoint"] = false;
          options.Value["CreateSurfIndex"] = 1;
          options.Value["GroupNameIndex"] = 0;
          options.Value["GroupName"] = "";
          options.Value["CEGroupLevel"] = 0;
          options.Value["CEPrefixCk"] = false;
          options.Value["CEPrefixString"] = "";
          options.Value["ImportUnit"] = 0;
          options.Value["CheckDuringLoad"] = false;
          options.Value["AutoStitchAndPromote"] = true;
          options.Value["AdvanceHealing"] = false;
          Object obj;
          StpAddin.Open(file, context, options, out obj);
          string iptName = String.Format(@"{0}\{1}.ipt", new_dir, temp_geo_code[j]);
Mark.Lancaster
@Anonymous
For better results, you should post over in the Inventor Customization forum (when it comes to programming questions).   I will have the moderator relocate your posting to better suit your needs.
Mark Lancaster
Thanks, I didn't notice I was writing in the wrong forum.
P
