Implementing touch screen and speech with inventor
To all,
I'm looking for a solution to keep on using Inventor despite severe RSI problems.
I'd like to customize a whiteboard for zooming, panning, rotating opbjects, right clicking and no double clicking,etc... I'm allready using 3Dconnection.
Does anyone know whiteboards that allow customisation with specific software(i.e. inventor) on top of windows7
I'm trying to use Dragon speech with inventor, but it's not easy. Tips&tricks?
Is it possible through VBA or other 'scripts' to get this done?
Are there any existing smart softwares to perform these actions.
Tx. Joris.
Some suggestions for RSI.
A great mouse for the right hand is the CM Storm Spawn. It is a claw grip style and has a place to rest the right ring finger. It is great.
Learn to use an ambidextrous mouse with the left hand. Also can use two mice, one to naviigate and one to click.The Navigator can be programmed to perform clicks, but I had trouble getting programming to hold.
Also get a chair that you can adjust the height of the arm rests. I had a chair that I was able to replace the right arm rest cushion with a 12" x 6" piece of plywood with a foam cushion glued on. Gives a larger area to rest the arm.
I also used a heavy duty very adjustable keyboard tray that I extended to the right for the mouse and to the left for 3D connexion Space Navigator.
I now use a variable height desk by Geekdesk. I made my own top out of a 4' x 8' sheet of plywood and added a plastic top. I cut out a 24" deep by 42" wide area to stand/sit in making a U with lots of accesable desk area. I can vary the height as needed for comfort.
Note: These helped me. I am doing what I can to work as long as I can. I have Parkinson's which limits the use of my right hand and arm. And if these things helped me they may help others.
Steve
xiaodong_liang
Autodesk Support
Autodesk Support
Hi joris.festjens,
I have not the experience with RSI. I am just wondering if the suggetion of janitor1 helps you? If yes, could you accept it as a solution?
