iMate suppress
iMate suppress
danijel.radenkovic
iMate suppress
danijel.radenkovic
I have an assembly which I need to show in two positions. First position has "1st_position" mate active ("2nd_position" mate is not active), Second position has 2nd_position mate active, 1st_position mate non active. It is showed on the image below.
I tried it through iAssembly to switch between two positions and to immediately update assembly. I hope someone can help me.
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
mitchjuenemann
Add a user multi-variable parameter that you want to flip the contraint switch in called "Position" with the values of 1 and 2.
Rename the constraints you wish to toggle on and off to 1st_position:1 and 2nd_position:1.
Add this rule to your assembly you wish to switch contraints on and off.
Make a Form if you wish or simply toggle the multi variable parameter you created in you parameters tab on 1 or 2 and you should be able to watch your assembly change position.
If Position = 1 Then
Constraint.IsActive("Your Assembly Name with Constraints on it:1", "1st_position:1") = True
Constraint.IsActive("Your Assembly Name with Constraints on it:1", "2nd_position:1") = False
Else If Position = 2 Then
Constraint.IsActive("Your Assembly Name with Constraints on it:1", "1st_position:1") = False
Constraint.IsActive("Your Assembly Name with Constraints on it:1", "2nd_position:1") = True
Hope this helps...
MItch
danijel.radenkovic
Hello Mitch,
Thank you very much for the answer. It helped and now works fine. I have conected multi-value parameter with form for the swithing between two values.
I thought that I can do it through iassembly but I didn't succeed.
Best regards and thank you very much.
Danijel
mitchjuenemann
I think you could have just used positional representation and achieved the same result.
danijel.radenkovic
Your solution works fine 🙂
Regards
Danijel
