iLogicto read Browser
JorisSteurs1246
JorisSteurs1246
Is it possible to read with iLogic the first .ipt or .aim from the browser tree in an assembly?
I need to know what that part name is so that I can replace it with another part using iLogic.
I've a function already that reads all the files , but I need very specifically to read the first file , or second for that matter, as long as it reads exactly the file that I point to.
All help really appreciated 🙂
See how you get on with this.
On Error Resume Next
'Counts for the number of components in an assembly
Dim myDoc As Document
doc = ThisDoc.Document
myDoc = ThisApplication.ActiveDocument
If doc Is mydoc Then
' a counter starting at zero and going up by one for each component in the assembly
Dim counter As Integer = 0
'Grab the Assembly Document
Dim oDoc As AssemblyDocument
oDoc = ThisDoc.Document
'Grab the Active Assembly Component Definition
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
' Get the model browser
Dim oPane As BrowserPane
oPane = oDoc.BrowserPanes.Item("Model")
Dim AssySubtype As String
AssySubtype = "Assembly"
' Grab the occurrence of the object
Dim oOcc As ComponentOccurrence
For Each oOcc In oDoc.ComponentDefinition.Occurrences
counter = counter + 1
'this is the magic number that will decide whether  your code is fired or on not
If counter = 1 Then
'your code here
Next
Jef_E
I don't get what you mean.. You state 3 different cases? the first, the first/second, the file you point to?
  • Do you want to read the filename/partnumber of the top item in the browser?
  • Do you want to read the filename/partnumber for selected item(s)?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Jef_E
Why not point to the item number instead of starting a loop that runs through all occurrences if only occurrence 1 is required?
oOcc = oDoc.ComponentDefinition.Occurrences.item(1)
Inventor 2014 SP2
JorisSteurs1246
Thank you guys, I got my code working using  the input of  SutherNe   but I  accepted  the code of Jef_E as solution.
Jef_E code also works for me and is much more simple.
To Answer your question Jef_E yes the code had to specify to a specific location in the browser  and with your code I can do so by changing .item(1) into another number.
Jef_E
Could you please post your finished code? It's nice for other user that have the same question to have a finished result.
Inventor 2014 SP2
JorisSteurs1246
No problem,
So far this seems to work nicely
' Define new part
Dim oReplacer As String
' Below replace with your replacing part / assy
oReplacer = "C:\Users\kasutaja\Documents\Inventor\Cadsherpa work\AUTO_Stair_1\REV1\parts\Standard\Fasteners\DIN 933 - M10  x 30 - St.ipt"
oPartName = (oOcc.Name) ' get name
    If Component.IsActive(oPartName) = True Then
        Try
           Component.Replace(oPartName, oReplacer, True)'replace
        Catch
        MessageBox.Show("Could not replace: " & oPartName , "ERROR")
        End Try
    Else
    MessageBox.Show("The part to replace is not active", "NOT REPLACED")
