OK. Sorry to hear that you were not able to fix it easily. Did you have a lot of custom 'Snippets' saved in your iLogic Snippets area? If so, did you ever export those settings out into an external XML file? If so, then you may be able to restore those when you have it all back up and running again, by going to the Custom side, then using the folder icon to open the custom snippets file again.
I have a ton of custom snippets stored on the 'Custom' side, in a long scrolling list of categories, and periodically export them to be safe, because they are pretty important to me and my daily work. I sometimes even store a copy of that exported file in a secondary place, just to be extra safe. It is a good practice to get into if you are planning to write or edit a lot of your own iLogic rules.
Wesley Crihfield
(Not an Autodesk Employee)
