iLogic
iLogic
mohandis2
iLogic
mohandis2
I have a more then 1500 parts assembly, these parts are driven from a big multi-body parts using "Make components" command,
when I update the assembly, it takes hours, and my best way is to leave inventor working overnight,
or open individual parts, update, save and close every single one, which is a very long process.
I'm looking for an iLogic that will update only selected parts within the assembly, see screenshot
any help please?
Ralf_Krieg
Hello
You can select the occurences you want to update and run this iLogic rule below. It's only with a few prechecks, so be please careful and test with a copy if possible.
If ThisDoc.Document.DocumentType IsNot DocumentTypeEnum.kAssemblyDocumentObject Then
	MsgBox("You need an assembly document to run this rule", , "iLogic error")
	Exit Sub
Dim oAssDoc As AssemblyDocument = ThisDoc.Document
If oAssDoc.ComponentDefinition.Occurrences.Count = 0 Then
	MsgBox("No occurences to update ", , "iLogic error")
	Exit Sub
If oAssDoc.SelectSet.Count = 0 Then
	MsgBox("Select at least one occurence before run this rule", , "iLogic error")
	Exit Sub
Dim oObj As Object
For Each oObj In ThisDoc.Document.SelectSet
    If TypeOf oObj Is ComponentOccurrence Then
        Call oObj.ReferencedDocumentDescriptor.ReferencedDocument.Update
Next
R. Krieg
RKW Solutions
www.rkw-solutions.com
Ralf_Krieg
Sorry, made a mistake in line 1.
If Not ThisDoc.Document.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
	Exit Sub
	Exit Sub
	Exit Sub
Dim oObj As Object
Next
R. Krieg
RKW Solutions
mohandis2
worked great, thanks.
