I am essentially trying to create my own copy design tool. This is a much simplified method of how it works
- open blank assembly (A)
- import required template assemblies (B & C)
- for each occurence in A, open, do a save as new part number
- do the same for its drawing and replace its referances
- repeat for all sub occurences.
-SAVE A here (not working!)
Most of this is working fine. When i open Assembly B, all its children have been saved and replaced as expected. (When i close it, inventor does not prompt me to save.) If i close all my assemblies down (no save prompt), and re-open assembly B all the childern in assembly B have gone back to the Template files. I.e. assembly B is not saving.
I am using both
docA.save and docA.save2(True)
I am disabling the vault addin before i run my rule, and re-enabling it at the end of the rule to get rid of those prompts to check out the template files. Is this the cause of the problem?
