Here is skinny on what I've got and what I'm trying to do.
I have a rule set on a part model template that assigns a company specific number to a customer property based off on material grade and thickness. That works great and populated the property as expected.
iProperties->Custom tab-> "Material ID" is the property. The format is "XXXXXX-XXXX" ex: 123456-1234
Now I'm trying to create a rule that will read this property and if the property reads "XXXXXX-0000" I want it to prompt the user with a message box that tells them to contact purchasing. I don't at all care what the numbers are for first 6 Xs only the -0000.
This is my code thus far. If I have it search for a number, 123456-0000, it will prompt just as expected. Everything I have found online for a Wildcard search doesn't prompt any results even thou I know they exist. I put the X's in my code below to show where I want the wild card function.
If iProperties.Value("Custom", "MATERIAL ID") = "XXXXXX-0000" Then MessageBox.Show("PLEASE REQUEST A SUPPLY CHAIN NUMBER FOR THIS MATERIAL", "Material Prompt", MessageBoxButtons.OK) End If
