iLogic View Label for all views on select sheets
LFMarshall
Message 1 of 8
LFMarshall
For several months I've been trying to get an iLogic rule to work but keep coming up short.  Any assistance would be greatly appreciated.
I've been able to piece together code from others to get most of the way there, but I need just one little piece to get over the hump.
What I'm looking for is to change all of the view labels on a single sheet (of flat patterns), with the Sheet Name "CUT FILES" to the Part Title and Description iprops of the part in the view.  This particular sheet is in a drawing with multiple sheets, but typically only one will have the name "CUT FILES".  I would like to set this rule to run prior to save, to ensure consistency in view labeling so having a code that only runs on one sheet is not ideal.
Below is the rule that I have together at this point, but it doesn't work.  It seems to just quit when it gets to SyntaxEditor Code Snippet
If ActiveSheet.Name IsNot "CUT FILES" Then Continue For
 If I remove that particular line the code runs, but on every view on every sheet.
Dim oDoc As DrawingDocument:  oDoc = ThisDoc.Document
Dim oSheets As Sheets
Dim oSheet As Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
oSheets = oDoc.Sheets
For Each oSheet In oSheets
		oViews = oSheet.DrawingViews
		For Each oView In oViews
				If oView IsNot Nothing Then
				oView.ShowLabel = True
				'format the model iproperties
				oStringTitle = "<StyleOverride Underline='True' FontSize='1.27'> <Property Document='model' PropertySet='Summary Information' Property='Title' FormatID='{F29F85E0-4FF9-1068-AB91-08002B27B3D9}' PropertyID='2'>TITLE</Property></StyleOverride>"
				oStringDescription = "<Br/><StyleOverride FontSize='1.27'>   <Property Document='model' PropertySet='Design Tracking Properties' Property='Description' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='29'>DESCRIPTION</Property></StyleOverride>"
				'add to the view label
				oView.Label.FormattedText = oStringTitle & oStringDescription
        Next
Next
LM
Inventor 2018
Larry Marshall
Inventor 2021.2 , AutoCAD 2021, 3DS Max 2021
Replies (7)
Message 2 of 8
philip1009
Try using <> instead of IsNot.
Message 3 of 8
LFMarshall
Thanks for the suggestion, unfortunately, that just crashed the program when I ran the rule.
Larry Marshall
Message 4 of 8
It looks to me like you are only looking at one sheet. (ActiveSheet.name) I believe if you change that to oSheet the logic will look at all pages. You might then have to assign oSheet to ActiveSheet before going through the views.
kl
Message 5 of 8
marcin_otręba
as @Anonymous said you shoud use osheet instead active sheet if you want to check names of all sheets and you dont activate it one by one..
so this is the code:
    If oSheet.Name <>"CUT FILES" Then 'Continue For - you dont need this
        Next
Next
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 6 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
Hello @LFMarshall,
Try below iLogic to check sheet name
Dim oSheet As Sheet
	oSheet.Activate
	If oSheet.Name.StartsWith("CUT FILES") = False Then
        	Next
Next
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 7 of 8
LFMarshall
        Next
Next
One of the Ifs, didn't have a terminator and when I added an End If it crashed the program.  When I removed the End If and added the Continue For back to the code it seems to be working as expected.  I don't claim to know why, and maybe I had done something incorrectly, but it seems to be working now.  Thank you for the help.
For reference, here is complete code that seems to be working.
Dim oSheet As Sheet
    If oSheet.Name <> "CUT FILES" Then Continue For
        Next
Next
Larry Marshall
Message 8 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
That's nice to hear that it is working.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
