ILOGIC / VBA: rename default plans
amarcoc
amarcoc
Hi.
I want to rename the default plans with a ilogic or macro function (in both assembly and part files)
I searched and tried, but couldnt do it.
Any ideas?
amarcoc
Answered myself:
For Each oWorkPlane In ThisDoc.Document.ComponentDefinition.WorkPlanes
	Select Case oWorkPlane.Name
		Case "YZ Plane - RIGHT", "XZ Plane - TOP", "XY Plane - FRONT"
			oWorkPlane.Visible = False
		Case "YZ Plane"
			oWorkPlane.Name = "YZ Plane - RIGHT"
		Case "XZ Plane"
			oWorkPlane.Name = "XZ Plane - TOP"
		Case "XY Plane"
			oWorkPlane.Name = "XY Plane - FRONT"
		Case Else
			'MessageBox.Show("Planos não encontrados", "Planos")
	End Select
Next
It renames and hides specific plans.
Thanks!
Jef_E
I believe this code would be better without the last else statement, this will result in many message boxed is there are more planes than just the default plane.
		Case "YZ Plane"
		Case "XZ Plane"
		Case "XY Plane"
	End Select
Next
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
amarcoc
Thank you.
That message was only for debugging.
In fact, in latest version I removed it.
