ilogic VBA InStrRev not reversing
cbn56B4Z
cbn56B4Z
i want it to find the project folder and the project name, so i tell it to find the constant value (427, our office number)
but for some strange reason  InStr and InStrRev both return the same number rather than reversing the search direction. what's wrong with my code?
'dims
oPath = ThisDoc.Path
'get base project folder placement
oGet01 = InStr(oPath, "427")-1
oSet01 = Left(oPath, oGet01)
'get project name
oGet02 = InStrRev(oPath, "427")-1
oSet02 = Right(oPath, oGet02)
oGet03 = InStr(oSet02, "\")
oSet03 = Left(oSet02, oGet03)
MessageBox.Show("Get1: " & oGet01 & vbCrLf & "Set1: " & oSet01 & vbCrLf & "Get2: " & oGet02 & vbCrLf & "Set2: " & oSet02 & vbCrLf & "Get3: " & oGet03 & vbCrLf & "Set3: " & oSet03)
WCrihfield
Are you using iLogic or VBA?  Similar code exists in both environments, but they're not exactly the same.
See these links:
VB.NET versions
Strings.InStr Method
Strings.InStrRev(String, String, Int32, CompareMethod) Method
VBA versions
InStr function
InStrRev function
Wesley Crihfield
(Not an Autodesk Employee)
JhoelForshav
Hi @cbn56B4Z
Is the document you're running the rule in saved? Otherwise ThisDoc.Path will return an empty string..
Have you tried using the DesignProjectManager object?
Something like this maybe?
Dim oActiveProject As DesignProject = ThisApplication.DesignProjectManager.ActiveDesignProject
MsgBox("Workspacepath:	" & oActiveProject.WorkspacePath & vbCrLf _
& "Project name:	" & oActiveProject.Name)
cbn56B4Z
@WCrihfield i'm using ilogic
@JhoelForshav sorry for the misunderstanding, but when i said project i did not literally mean project file, we run a single project folder via Vault, that project is split into years and then split into each "collection" i will call it instead, i need to get this "collection" number, not the project.
cbn56B4Z
@WCrihfield i managed it wouthout InStrRev. using Mid instead
skimming the two InStrRev in iLogic
InstrRev(stringcheck, stringmatch, [ start, [ compare ]])
InStr([ start ], string1string2, [ compare ])
they are basically the same, but they moved the [ start ] value.
if anybody knows of a reverse string search do tell.
anyways, here's my ugly solution for anybody who cares:
'dims
'get project name
oGet02 = InStr(oGet01 + 1, oPath, "\")-1
oSet02 = Left(oPath, oGet02)
oGet03 = InStrRev(oSet02, "\")
oSet03 = mid(oSet02, oGet03+1)
