ILogic/ VBA, How can I access to all parts properties in assembly from up to down?
Message 1 of 9
I Have a assembly and I just one to change part number form 00 - 99, with order from up to down (please look at the picture).
I tried the code , but it open all file in assembly with a random order, it's hard to fill all part number. In addition, is there possible to access just top level parts? (Not the parts inside level 2-assembly)
openDoc = ThisApplication.ActiveDocument
Dim docFile As Document
For Each docFile In openDoc.AllReferencedDocuments
Next
 Please help.
Replies (8)
Message 2 of 9
FINET_Laurent
What do you mean when changing par number?
From what I understand :
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oOccurrence As ComponentOccurrence
Dim iInteger As Integer = 0
Dim oStr As String
For Each oOccurrence In oAsmCompDef.Occurrences
	iInteger = iInteger + 1
	oStr = iInteger
		oOccurrence.Name = oStr
Next
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Message 3 of 9
FINET_Laurent
I'll add the 00.
Dim oStr As String
	If iInteger < 10 Then
		oStr = "0" & iInteger
	Else If iInteger > 9 Then
		oStr = iInteger
Next
Message 4 of 9
thank you for reply.
I meant I wanted to set part number in order (from up to down). Like 00.01, 00.02, 00.03 ...; But my code access to parts randomly, doesn't go from up to down, and it accesses to all assembly documents and the parts inside them too. I just want to access to all parts on top-level .
Message 5 of 9
Hi @Anonymous . Try this:
Dim oDoc As AssemblyDocument = ThisAssembly.Document
Dim newPartNum As Integer = 0
Dim asmDef = oDoc.ComponentDefinition
For Each occ As ComponentOccurrence In asmDef.Occurrences
	Dim occDoc As Document = occ.Definition.Document
	newPartNum = newPartNum + 1
	occDoc.PropertySets("Design Tracking Properties")("Part Number").Value = "Text " & newPartNum & " AnotherText"
Next
After running the code, right click the parts and check the iproperties.
Message 6 of 9
Thank you sir, but your code doesnt work. "part number" cant write on. but thank you anyway.
Message 7 of 9
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.Property.set_Value(Object )
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Message 8 of 9
Nevermind sir, I found the solution.
Message 9 of 9
mseveroLXMQ8
What's the solution?
