[iLogic / VBA ] Change drawingcurves color based of property (e.g. Description)
Luisfmts
Luisfmts
Hi Folks,
I have something in mind, but idk where i'm missing the point on the way:
I'd like to change the color of the drawing curves based on a property of the part or assembly e.g.: if description = "blue" then drawing curves of the assy (or part).color = 0,0,255.
Is there a simple way for doing this?
For VBA and up to the part of differentiation of the disered description i get it...I'm almost sure my problem is how to get the drawing curves from the part (or assy) that is a match, and change its properties.
I'd appreciate any ideas Smiley Happy
Hi. No idea. Smiley Happy
Sub PickToPaint()
    Dim oDocActive As Document
    Set oDocActive = ThisApplication.ActiveDocument
    If oDocActive.DocumentType = kDrawingDocumentObject Then
        Dim oDrgDoc As DrawingDocument
        Set oDrgDoc = oDocActive
        Dim oSheet As sheet
        Set oSheet = oDrgDoc.ActiveSheet
        Dim drawView As DrawingView
        Set drawView = ThisApplication.CommandManager.Pick( _
                 kDrawingViewFilter, "Pick DrawingView to paint..")
        If drawView Is Nothing Then Exit Sub
        PaintDrawingView drawView ', ThisApplication.TransientObjects.CreateColor(0, 255, 0)
    Else
        MsgBox "This macro works in IDW"
End Sub
Sub PaintDrawingView(oDrawingView As DrawingView, Optional oColor As color = Nothing)
    Dim paintColor As color
    If oColor Is Nothing Then
        Dim oRefFileDesc As ReferencedFileDescriptor
        Set oRefFileDesc = oDrawingView.ReferencedFile
        Dim oDoc As Document
        Set oDoc = oRefFileDesc.DocumentDescriptor.ReferencedDocument
        Dim opropsets As PropertySets
        Set opropsets = oDoc.PropertySets
        Dim oPropDescription As Property
        Set oPropDescription = opropsets.item("{32853F0F-3444-11d1-9E93-0060B03C1CA6}").ItemByPropId(kDescriptionDesignTrackingProperties)
        Select Case oPropDescription.Value
            Case "Blue", "blue", "BLUE"
                Set paintColor = ThisApplication.TransientObjects.CreateColor(0, 0, 255)
            Case "Red", "red", "RED"
                Set paintColor = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
            Case Else
                Set paintColor = ThisApplication.TransientObjects.CreateColor(128, 128, 128)
        End Select
   Else
    Set paintColor = oColor
    Dim oDrawingCurve As DrawingCurve
    For Each oDrawingCurve In oDrawingView.DrawingCurves
        oDrawingCurve.color = paintColor
    Next oDrawingCurve
End Sub
    Select Case oDrawingCurve.CurveType
        Case _
            CurveTypeEnum.kCircleCurve:
                oDrawingCurve.color = ThisApplication.TransientObjects.CreateColor(255, 255, 0)
        Case _
            CurveTypeEnum.kCircularArcCurve, _
            CurveTypeEnum.kEllipseFullCurve, _
            CurveTypeEnum.kEllipticalArcCurve:
            If oDrawingCurve.EdgeType = DrawingEdgeTypeEnum.kThreadEdge Then
            Else
        Case _
            CurveTypeEnum.kLineCurve, _
            CurveTypeEnum.kLineSegmentCurve:
            If oDrawingCurve.EdgeType = DrawingEdgeTypeEnum.kBendDownEdge Then
            ElseIf oDrawingCurve.EdgeType = DrawingEdgeTypeEnum.kBendUpEdge Then
            ElseIf oDrawingCurve.EdgeType = DrawingEdgeTypeEnum.kBendExtentEdge Then
            Else
        Case CurveTypeEnum.kPolylineCurve:
            'MsgBox ("Polyline") 'reserved for later
        Case CurveTypeEnum.kBSplineCurve:
             oDrawingCurve.color = ThisApplication.TransientObjects.CreateColor(255, 255, 255)
        Case CurveTypeEnum.kUnknownCurve:
            'MsgBox ("Unknown") 'reserved for later
        Case Else:
    End Select
Next oDrawingCurve
Luisfmts
Wow...that was cool, and ellegant piece of code... Worked very well for top referenced document. Smiley Happy
I'm wondering if it could be adapted to get the result as image attached (one view with one assembly, multiple parts, each part different color)
I think i'm stucking on this part:
    Next oDrawingCurve
I was thinking instead of getting all drawing curves on the view get only the ones of the occurrence:
    For Each oDrawingCurve In oDrawingView.oOccurrence.DrawingCurves
    Next oDrawingCurve
What do you think?
Hi Luis.
If there are sub assemblies you must find a better way.
This is for all levels of parts - only.
Sub PickDrawingViewToPaintParts()
        PaintPartsInDrawingView drawView
    Else
End Sub
Sub PaintPartsInDrawingView(oDrawingView As DrawingView)
    Dim descriptionString   As String
    Dim bDoNotPaint         As Boolean
    On Error Resume Next
        bDoNotPaint = False
        descriptionString = Get_DocDescription(oDrawingCurve.ModelGeometry.ContainingOccurrence.Definition.Document)
        If Err.Number = 0 Then
            Select Case descriptionString
                Case "Yellow", "yellow", "YELLOW"
                    Set paintColor = ThisApplication.TransientObjects.CreateColor(255, 255, 0)
                Case "Green", "green", "GREEN"
                    Set paintColor = ThisApplication.TransientObjects.CreateColor(0, 255, 0)
                Case Else
                    bDoNotPaint = True
                    ''Set paintColor = ThisApplication.TransientObjects.CreateColor(0, 0, 0)
            End Select
            If Not bDoNotPaint Then oDrawingCurve.color = paintColor
        Else
            ''oDrawingCurve.color = don't paint this curve
            Err.Clear
    Next oDrawingCurve
    MsgBox "Complete"
End Sub
Function Get_DocDescription(oDoc As Document) As String
    Dim oDocPropSets As PropertySets
    Dim oDocPropDescription As Property
    Dim oDocDescription As String
    Set oDocPropSets = oDoc.PropertySets
    Set oDocPropDescription = oDocPropSets.item("{32853F0F-3444-11d1-9E93-0060B03C1CA6}") _
    oDocDescription = oDocPropDescription.Value
    Get_DocDescription = oDocDescription
End Function
My poor codes.
Luisfmts
Hi hrnkilic. That worked just fine for parts only (just tested). Thanks 🍺🍺 Smiley Happy
[404: no poor codes found]
