iLogic Values Input
iLogic Values Input
rdiamond113
iLogic Values Input
rdiamond113
All,
I am creating a rule that when I enter a pre-defined color in my assembly, the part number for one of the components will be updated to a color specific part number. My issue is I only have one pre-defined color, so what would I display in the rule for my ElseIf statement? Would it be "Variable" or "Multi-something" or "Any"? I've searched everywhere and cannot find what value I would use. Also I cannot use a Multi-Value list because it would be endless. Please Help!
Product Design Suite 2015, Windows 7, 64 bit
"Pushing the envelope, just to watch it bend"
VdVeek
You don't need to use the ElseIf statement if you only got 2 options (Defined Color / All other colors).
Your code can look like this:
If color = "red" Then
' Change Partnumber to ....
Else
'Don't change Partnumber for all other colors
When you want to define more colors it's easier to use a case statement.
Hope i understand your question correctly.
Rob.
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
rdiamond113
But I also need the part number to change for all other colors, so essentially I have two part numbers, one for a certain color and one for all others. Can I still use the Else statement and say Change Partnumber for all other colors?
VdVeek
Yes you can still use the Else statement.
