iLogic User Parameters not affecting certain parts
btomosonEYBLL
btomosonEYBLL
I am trying to use iLogic to suppress or show a feature in multiple parts from an assembly.
I first started with creating a list item user parameter in all of the parts named "Color"
I then set a rule in all of those parts to update the feature using select case.
Part 1:
Select Color
	Case "White"
	' ***Extrusion11***
	Feature.IsActive("Extrusion11") = False
	Case "Midnight/Midnight"
	' ***Extrusion11***
	Feature.IsActive("Extrusion11") = True
	Case "Midnight/White"
	' ***Extrusion11***
	Case "Sandstone"
	' ***Extrusion11***
	Case "Tan"
	' ***Extrusion11***
End Select
 Part 2:
Select Color
	Case "White"
	' ***Extrusion7***
	Feature.IsActive("Extrusion7") = False
	' ***Extrusion7***
	Feature.IsActive("Extrusion7") = True
	' ***Extrusion7***
	Case "Sandstone"
	' ***Extrusion7***
	Case "Tan"
	' ***Extrusion7***
End Select
Part 3:
Select Color
	Case "White"
	' ***Extrusion14***
	Feature.IsActive("Extrusion14") = False
	' ***Extrusion14***
	Feature.IsActive("Extrusion14") = True
	' ***Extrusion14***
	Case "Sandstone"
	' ***Extrusion14***
	Case "Tan"
	' ***Extrusion14***
End Select
These Rules all work and were tested by forms in the individual part files.
In the assembly file with all of these parts, I created a rule that set the user parameter in the part = to the assembly user parameter of the same name.
'Color
Parameter("Part1", "Color") = Color
Parameter("Part2", "Color") = Color
Parameter("Part3", "Color") = Color
 The only part that updates is Part1. The others do not reflect any changes. This happens even if I comment out all of the other parts in the assembly.
I am unsure why only one of my parts is updating in the assembly yet they all work the same in their individual part files.
btomosonEYBLL
My extrusion naming scheme was off by 1 and I was changing the wrong feature. This has been fixed.
