iLogic user parameter + assembly issue
Hello, I have a piece of code that I would like to understand why it doesn't work.
The code should look for the parameter user parameter called "TypePiece", and if it doesn't find it, it should create it as a multivalue list. I modified the original code a tiny bit, because I would sometime have an error popping up when it was trying to populate an assembly document's user parameters, so I declared _Piece and _Asm as PartDocument and AssemblyDocument, to stop that error.
Now, It won't populate my assembly, but it does populate parts. Is there a reason? If so, how can I correct it please? Thanks!
Try
	Parameter("TypePiece") = Parameter("TypePiece")
Catch
	If _FichierType = "Pièce" Then
		_Piece = ThisApplication.ActiveDocument
		For Each oParam As UserParameter In _Piece.ComponentDefinition.Parameters.UserParameters
			DefinitionParametre = _Piece.ComponentDefinition.Parameters.UserParameters
			oTypePiece = oParam.Value
			Try
			Catch
				ParametresPiece = DefinitionParametre.AddByValue("TypePiece", oTypePiece, UnitsTypeEnum.kTextUnits)
				MultiValue.SetList("TypePiece", "Principale", "GalvPeint", "Securite", "Grillage", "Usinage", "TraySol", "Autre1", "Autre2", "Autre3", "Autre4", "NonPeint")
			End Try
		Next
	Else If _FichierType = "Assemblage" Then
		_Asm = ThisApplication.ActiveDocument
		For Each oParam As UserParameter In _Asm.ComponentDefinition.Parameters.UserParameters
			DefinitionParametre = _Asm.ComponentDefinition.Parameters.UserParameters
			Try
			Catch
			End Try
		Next
End Try
Ralf_Krieg
Hello
I would separate part and assembly in two different functions.
Sub Main
	Dim oUParam As UserParameter
	If ThisDoc.Document.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
		oUParam=SetUserParamAss(ThisDoc.Document )
	ElseIf ThisDoc.Document.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
		oUParam=SetUserParamPart(ThisDoc.Document)
	If oUParam Is Nothing Then
		MsgBox("Parameter not created", , "iLogic SetUserParameter")
		Exit Sub
End Sub
Private Function SetUserParamPart(ByVal oPartDoc As PartDocument) As UserParameter
	Try
		For Each oUParam In oPartDoc.ComponentDefinition.Parameters.UserParameters
			If oUParam.Name="TypePiece" Then Return oUParam
		Next
		SetUserParamPart=oPartDoc.ComponentDefinition.Parameters.UserParameters.AddByValue("TypePiece", "Principale", UnitsTypeEnum.kTextUnits)
	Catch
		Return Nothing
	End Try
End Function
Private Function SetUserParamAss(ByVal oAssDoc As AssemblyDocument) As UserParameter
	Try
		For Each oUParam In oAssDoc.ComponentDefinition.Parameters.UserParameters
		Next
		SetUserParamAss=oAssDoc.ComponentDefinition.Parameters.UserParameters.AddByValue("TypePiece", "Principale", UnitsTypeEnum.kTextUnits)
	Catch
		Return Nothing
	End Try
End Function
R. Krieg
RKW Solutions
www.rkw-solutions.com
