iLogic: use DocumentUnitsMatrix to reposition existing component
I want to be able to place a component or move an existing component to a given position and rotation.
My code:
Function PlaceComponentAtCoordinates(SpecificComponentName As String, ComponentPath As String, RotationX As Double, RotationY As Double, Distance As Double)
		Dim Pos_Matrix As DocumentUnitsMatrix  = ThisAssembly.Geometry.Matrix(RotationX, 	0, 			0, Distance,
							                                               0, 			RotationY,	0, 0,
							                                               0,			0,			1, 0,
							                                               0,			0,			0, 1)
		If Not ComponentExists(SpecificComponentName) Then
			' This works fine
			Components.Add(SpecificComponentName, ComponentPath, Pos_Matrix, grounded := True)
		Else
			Dim oOccurrence As ComponentOccurrence = Component.InventorComponent(SpecificComponentName)
			' This doesn't work
			oOccurrence.SetTransformWithoutConstraints(Pos_Matrix)
End Function
' Input parameter: Component name
' Returns: True if component exists. False if it doesn't exist.
Function ComponentExists(ComponentName As String) As Boolean
End Function
Placing the component using Pos_Matrix works fine, but changing the position doesn't, because "Unable to cast object of type 'Autodesk.iLogic.Types.DocumentUnitsMatrix' to type 'Inventor.Matrix'."
 How can I solve it?
JhoelForshav
Hi @Anonymous
SetTransformWithoutConstraints takes an argument of type Matrix. Therefore we'll have to convert your DocumentUnitsMatrix to Matrix. I havn't tried it but I'm pretty sure this will do 🙂
	0, RotationY, 0, 0,
	0, 0, 1, 0,
	0, 0, 0, 1)
		' This works fine
	Else
		oOccurrence.SetTransformWithoutConstraints(Pos_Matrix.InDatabaseUnits)
End Function
DocumentUnitsMatrix.InDatabaseUnits returns an object of type Matrix 🙂
It worked perfectly, thanks! 😄
