ILogic/Update the drawing to the first configuration.
aleksei.lipatnikov
aleksei.lipatnikov
Good morning everybody,
i wonder if there is a solution to reset the drawing.
For Example, i am using the existing drawing futher *saving as copy) and i need to delete some views and put an extra view. The Name of the new View will be as continued next Letter .... is it possible to write an Ilogic rule to reset this situation bach to zero?
Appriciate for help.
Let me see if I understand what you are wanting to do. Currently you have a number of views, lets say 4, named A, B, C, D. You want to delete views C and D to place a new view. Inventor is placing the new view as E, but you want it placed as C. Is that correct?
aleksei.lipatnikov
That is right, i want to clean the drawing environment if i delete the view, so when i will place the next view - the name will be the right one.
