iLogic Trigger event bug ?
ThomasB44
Mentor Mentor
ThomasB44
I'm having a strange problem with iLogic trigger events.
A trigger event suddendly appeared to all my files : new files, recent files, and old files. IPT, IAM, DWG files also.
So it seems to appear suddendly to thousand files.
And I can't suppres it :
This rule is one of my external rules, to launch from a drawing, so when I open an assembly I have an error message for each file...😱
But how this could happen ?
And how fix it ? 😥
Here attached some example files to be sure.
PS : A few days before the end of the contest, hooo !
Thomas
Mechanical Designer / Inventor Professional 2025
Inventor Professional EESignature
mcgyvr
Look on the "All Documents"  (Tous Les Documents) tab.
Any rules set there?
Maybe you accidentally added it there vs "this document" tab..
ThomasB44
Incredible, thanks again @mcgyvr 😉
I would never found this...as this is not my usual practices. A rule can't be set for all documents to me.
Perhaps a bad click from me with working from home...
Thanks a lot ! 😄
Thomas
