Ilogic to update design view in assembly
I have an assembly that contain subassembly with Ilogic to control occurence visibility,
what i'm trying to do, is make an Ilogic in the main assembly to update all subassembly to be  associative design view representation to default
I've been trying a few different rules, but i missing something to make it work well.
If someone have an idea that will be very appreciated
dgreatice
You can try this code:
Dim oAssydoc As AssemblyDocument
oAssydoc = ThisApplication.ActiveDocument
Dim oCompDef As AssemblyComponentDefinition
oCompDef = oAssydoc.ComponentDefinition
Dim oCC As ComponentOccurrence
oCC = oCompDef.Occurrences.Item(1) 'or
'oCC = oCompDef.Occurrences.ItemByName("type here your component name")
'default = Representation View at Occurence index 1
'true = Assosiative are Enable
Call oCC.SetDesignViewRepresentation("Default", , True)
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Many thanks dgreatis , this code doing exactly what I was looking for.
KenVaessen
	'Representation on Default and associative
	Dim doc As AssemblyDocument = ThisDoc.Document
	Dim oAsmCompDef As ComponentDefinition
	Dim oCompOcc As Inventor.ComponentOccurrence
	oAsmCompDef = doc.ComponentDefinition
	For Each oCompOcc In oAsmCompDef.Occurrences
	If oCompOcc.Visible = True Then
	If oCompOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
	oCompOcc.SetDesignViewRepresentation("Default", True)
	Else
	Else
	On Error Resume Next
	Next
	ThisApplication.ActiveView.Fit
