iLogic to toggle sub-assembly BOM structure
b.mccarthy
b.mccarthy
I have this assembly, containing a number of sub-assemblies and parts. I am looking for a routine that will temporarily toggle the sub-assembly's BOM structure from Normal to Phantom and back again, ignoring the parts.
I found this 2012 post which can perform the toggle, but could not get it to work the way I need. I am not a proficient coder...
Thank you for any help...
JelteDeJong
You can try something like this:
Dim doc As AssemblyDocument = ThisDoc.Document
Dim names As New List(Of String)
names.Add("Phantom")
names.Add("Inseparable")
names.Add("Normal")
Dim BOMStructureName = InputListBox("Select BOM structure", names, "Normal", "Select", "BOM structures")
For Each refdoc As Document In doc.AllReferencedDocuments
    If (refdoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject) Then
        Select Case BOMStructureName
            Case "Phantom"
                refdoc.ComponentDefinition.BOMStructure = BOMStructureEnum.kPhantomBOMStructure
            Case "Inseparable"
                refdoc.ComponentDefinition.BOMStructure = BOMStructureEnum.kInseparableBOMStructure
            Case "Normal"
                refdoc.ComponentDefinition.BOMStructure = BOMStructureEnum.kNormalBOMStructure
        End Select
Next
Jelte de Jong
Blog: hjalte.nl - github.com
b.mccarthy
Hello.
Thank you for the code, but I am getting these errors.
JelteDeJong
These errors don't tell me much. Maybe you can try the following (updated) rule. Maybe it becomes clear if you know which document is failing. It will show a message box for each document that can't be updated. (try it on an assembly that is not too big or you might get stuck with a lot of message boxes 😉
Dim names(3) As String
names(0) = "Phantom"
names(1) = "Inseparable"
names(2) = "Normal"
Dim BOMStructureName = names(1)
        Try
                Case "Phantom"
                Case "Inseparable"
                Case "Normal"
            End Select
        Catch ex As Exception
            MsgBox("Could not set BOMStructure for document: " & refdoc.DisplayName)
        End Try
Next
Jelte de Jong
b.mccarthy
The form no longer displays, and I am getting these errors:
The 1st appears for every sub-assembly, and the 2nd for each bolted connection.
Thanks.
