iLogic to select by plane
andrew_canfield
andrew_canfield
Hello
Select by plane.JPGI'd like to delete(maybe suppress) everything 50m south of plane A on an imported sat file assembly.
I can use the existing tool 'select by plane' but would like to drive it by iLogic.
I can create & name the work plane positions to then create a cube. (6 planes in total)
Drop in a different sat file assembly & the code strip down the assembly to just the parts inside the cube.
I need to identify the work plane , select all parts on on side of the plane, suppress (or delete) the selected parts.
Save the result as..
If the imported sat file assembly is a sub-assembly the planes created in the top level assembly to do the cutting need to be used.
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @andrew_canfield,
Try the following iLogic code to perform "select by plane".
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oDef As AssemblyComponentDefinition
oDef = oDoc.ComponentDefinition
Dim oPlane As WorkPlane
oPlane = oDef.WorkPlanes.Item("XY Plane")
Dim oCommand As CommandManager
oCommand = ThisApplication.CommandManager
oCommand.DoSelect(oPlane)
Dim oCtrlDef As ControlDefinition
oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyEnhSelSelectByPlaneCmd")
oCtrlDef.Execute2(True)
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
