ilogic to replace letter in text location in drawings
Charlies_3D_T
Message 1 of 20
Charlies_3D_T
Can someon tell me if i can do a find for example letter a and replace it with b in a text in my drawings?
I have tekst 1 a2 and it has to be 1 b2 but i have multiple numbers with the letter a that has to be replaced.
Thanks for the help!
Replies (19)
Message 2 of 20
Sergio.D.Suárez
Hi, a while ago, I had this ilogic rule ready. This rule will replace a text specified in each note of your drawing file. I guess it has to work.
oDoc = ThisDoc.Document
Dim oSheets As Sheets
Dim oSheet As Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
Dim oGeneralNotes As GeneralNotes
Dim oGeneralNote As GeneralNote
Dim oSymbol As SketchedSymbol
Dim oSymbols As SketchedSymbols
Dim oTitleBlock As TitleBlock
Dim oTestBox As TextBox
Dim TXT2Find As String
Dim NewTXT As String
'get user input
TXT2Find = InputBox("Enter Text To Find:", "iLogic", "XXX")
'look for blank value
If TXT2Find ="" Then
Return 'exit rule
Else
'Continue rule
NewTXT = InputBox("Enter Text To Replace   '"& TXT2Find _
& "'  with.", "iLogic", "****")
oSheets = oDoc.Sheets
For Each oSheet In oSheets
    Try
    oGeneralNotes = oSheet.DrawingNotes.GeneralNotes
    'look at gerenal notes
    For Each oGeneralNote In oGeneralNotes
        If oGeneralNote.FormattedText = TXT2Find Then
        oGeneralNote.FormattedText = NewTXT
        Else
    Next
    oLeaderNotes = oSheet.DrawingNotes.LeaderNotes
    For Each oLeaderNote In oLeaderNotes
        If oLeaderNote.FormattedText = TXT2Find Then
        oLeaderNote.FormattedText = NewTXT
        Else
    Next
    oTitleBlock = oSheet.TitleBlock
    For Each oTextBox In oTitleBlock.Definition.Sketch.TextBoxes
                If oTitleBlock.GetResultText(oTextBox) = TXT2Find  Then
                oTitleBlock.SetPromptResultText(oTextBox, NewTXT )
        Else
        Next
    oSymbols = oSheet.SketchedSymbols
    'look at sketched symbols
        For Each oSymbol In oSymbols
            For Each oTextBox  In oSymbol.Definition.Sketch.TextBoxes
             If oSymbol.GetResultText(oTextBox)   = TXT2Find Then
             oSymbol.SetPromptResultText (oTextBox, NewTXT)
                Else
            Next
            Next
            Catch
            'do nothing here,
            'this simply catches errors, for
            'exampl: when a sheet has no title block
            End Try
Next
 I hope these lines of code can help you develop the code you need. Regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 3 of 20
Charlies_3D_T
@Sergio.D.Suárez
Thank you! But the problem here is that i just want to replace a letter in a text with an other letter. Is that something that is possible you think?
Message 4 of 20
Sergio.D.Suárez
Hello, the following simplified code should serve to replace a character or part of text with another one that you specify. I have prepared it in general notes and leadernotes.
I hope I can serve you to develop the code you need. Regards
'get user input
If TXT2Find ="" Then Exit Sub
For Each oSheet As Sheet In oDoc.Sheets
    For Each oGeneralNote As GeneralNote In oSheet.DrawingNotes.GeneralNotes
		oGeneralNote.FormattedText = oGeneralNote.FormattedText.Replace(TXT2Find,NewTXT)
    Next
    For Each oLeaderNote As LeaderNote In  oSheet.DrawingNotes.LeaderNotes
		oLeaderNote.FormattedText = oLeaderNote.FormattedText.Replace(TXT2Find,NewTXT)
    Next
Next
Mechanical Designer
Message 5 of 20
Charlies_3D_T
@Sergio.D.Suárez
You sir just made my day!
Thank you!
Message 6 of 20
I want to do the same thing. This is a leader note text. If I use this code it will delete the text but not the leader attached to it. Is it possible to delete the leader as well?
If I click the text, then the text including the leader will be selected and I can delete both in one click.
Now I use this code:
		oLeaderNote.FormattedText = oLeaderNote.FormattedText.Replace("C.O.G.", "")
    Next
Next
Message 7 of 20
@Stakin do you know what I have to do here? 🙂
Message 8 of 20
I would try this:
		If oLeaderNote.FormattedText.Contains("C.O.G.") = True Then
			oLeaderNote.Delete
    Next
Next
Message 9 of 20
That worked!
Could you merge your code with this code? I tried but got an error:
Dim oDrawingDoc As DrawingDocument
oDrawingDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
	oSheet = oDrawingDoc.ActiveSheet
Dim CenterMark As Centermark
For Each CenterMark In oSheet.Centermarks
	If CenterMark.CentermarkType = Inventor.CentermarkTypeEnum.kCenterOfGravityCentermarkType Then
		CenterMark.Delete()
Next
Message 10 of 20
Dim oDoc  As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim oLeaderNote As LeaderNote
For Each oSheet In oDoc.Sheets
    For Each oLeaderNote In oSheet.DrawingNotes.LeaderNotes
			oLeaderNote.Delete
    Next
		CenterMark.Delete()
	Next
Next
Message 11 of 20
Thank you!!
Message 12 of 20
Payne_S
This is very helpful. Is there a way for this to work with balloons too? For example, we have text in leaders and text in balloons that would need to be changed. Sometimes the text in the balloon is overridden. Any help is awesome! Thank you!
Message 13 of 20
Sergio.D.Suárez
Hi, to work with balloons you should try something similar to what I show you here.
Dim oDoc  As DrawingDocument = ThisDoc.Document
	For Each oBalloon As Inventor.Balloon In oSheet.Balloons
		oBalloon.BalloonValueSets.Item(1).OverrideValue = oBalloon.BalloonValueSets.Item(1).Value & " - Testing"
    Next
Next
'oBalloon.BalloonValueSets.Item(1).Value
You can work with the overridden or directly define the value with the value.
In the example, put a simple routine so that you understand what is being done.
I hope this helps with your problem
Mechanical Designer
Message 14 of 20
Payne_S
Thank you for your help! I am not very familiar with coding and was hoping there was a find and replace ilogic code that could be used. We tag out valves and instruments with balloons. Sometimes the customer wants custom tags for each job where only the prefix changes.  So I was hoping there was a way to say "search for 1404 and replace with 1409"
Thank you again!
Message 15 of 20
Sergio.D.Suárez
Hi, I think this code could work, it is to overwrite the value of the balloon without changing the value of the balloon item
Dim TXT2Find, NewTXT As String
NewTXT = InputBox("Enter Text To Replace   '"& TXT2Find & "'  with.", "iLogic", "****")
		oBalloon.BalloonValueSets.Item(1).OverrideValue = _
		oBalloon.BalloonValueSets.Item(1).OverrideValue.Replace(TXT2Find, NewTXT)
	Next
Next
Next to change the balloon item
		oBalloon.BalloonValueSets.Item(1).Value = _
		oBalloon.BalloonValueSets.Item(1).Value.Replace(TXT2Find, NewTXT)
	Next
Next
 I hope this helps with your problem. Cheers!!
Mechanical Designer
Message 16 of 20
Payne_S
Hi Sergio,
The second code worked perfectly
 The one for overridden balloons gave me an error
"Object reference not set to an instance of an object."
Thank you again.
Message 17 of 20
G.Binl
Thank you very much for this logic, it worked very well some day Inventor will add this to the base system like every other program in the 20th century 🙂
Message 18 of 20
davis.j
MESSAGE 4 OF 17 works excellently. Thank you.
Message 19 of 20
G.Binl
@Sergio.D.Suárez
Hope you are well.
I have been trying to do a find and replace for Datums in drawings. im not sure what the come line would be
i keep coming across DrawingEditDatumTargetSymbolCtxCmd       but not sure that is the correct call out.
I'm trying to change 3.
in 3.1 & 3.2
to 2.1 & 2.2 respectfully
I'm using this code, Any help would be great.
'get user input
    For Each DrawingEditDatumTargetSymbol As DrawingDimension In oSheet.DrawingDimensions
       If DrawingEditDatumTargetSymbol.Text.FormattedText.Contains(TXT2Find) Then
           DrawingEditDatumTargetSymbol.Text.FormattedText = DrawingEditDatumTargetSymbol.Text.FormattedText.Replace(TXT2Find, NewTXT)
	Next
Next
Message 20 of 20
Alex.Shechter
I am trying to wrap my head around this code but my programming capabilities failing me.
Could someone please help me out?
I want to automate iProperteis Project Part Number to be searched and corrected.
The Part Number is built as following: XX-XXXX_XXX-XXXX
I want the code to search for the underscore and replace it with space
The end result should look like this: XX-XXXX XXX-XXXX
This is how far I got:
FileName = ThisDoc.FileName
iProperties.Value("Project", "Part Number") = FileName
TXT2Find = FileName
‘From here I don’t know how to do it right
NewTXT = TXT2Find _ & "'  with.", "iLogic", " "
‘The new changed text should be written to the part number iProperty
iProperties.Value("Project", "Part Number") = NewTXT
I just can’t wrap my head around how to get the text to be searched and replaced.
