Message 1 of 1
iLogic to Remove Image Frames in Title Block Template
We have title block templates that use different images per project. The idw template is saved as a dwg template so we can work on drawings between Inventor and AutoCad.
An image frame appears around the images when we open files in AutoCad and we are not able to use the IMAGEFRAME command in AutoCad to turn the image frame off.
Is there an image frame in Inventor that we can turn off iLogic or some method to remove the image frame?
Thank you!
