iLogic to Read ipt If Sheet Metal?
felix.cortes5K3Y2
felix.cortes5K3Y2
Hi forum,
I was looking for a code to check if the current opened document model is a sheet metal using iLogic and not the VBA editor
Best regards,
Felix
Sergio.D.Suárez
Hi,  with this code fragment you will determine if the part file is sheet metal.
Dim doc As PartDocument = ThisDoc.Document
If doc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
	MessageBox.Show("This file is sheet metal")
Else
	MessageBox.Show("This file is not sheet metal")
I hope this helps solve your problem. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
felix.cortes5K3Y2
Thanks Sergio!
