iLogic to Protected Excel
08:04 AM
Hi Guys,
I am using an iLogic code which writes values of the iProperties into an excel sheet in order to keep part numbers in Inventor linked with those in our part number database.
I am currently using the GoExcel syntax in order to do this.
However, I want to be able to protect and unprotect the sheet via the code so that in can only be changed through the ilogic and users cant interfere with the data.
Is there a way to do this using the GoExcel.Open syntax for example or the GoExcel.Application syntax.
Section = Left(Parameter("SECTION"),1) 'Type (mechanical, Fluid) Struct = Left(Parameter("STRUCTURE"),1) 'Assembly or Component 'define the file to create/open Worksheet = "Z:\CAD\DESIGN ENVIRONMENT\iLogic\PN.xlsx" Sheetno = ("Sheet1") 'check for existing file If Dir(Worksheet) <> "" Then 'workbook exists, open it GoExcel.Open(Worksheet, Sheetno) 'Set the values to write into excel part number database ' Define Range RowStart = 2 RowEnd = 10000 'Find the first empty cell For count = RowStart To RowEnd ' If it's blank count it If String.IsNullOrEmpty(GoExcel.CellValue("C" & count)) Then ' Row Number is equal to the current row rowN = count 'Exit For loop Exit For End If Next GoExcel.CellValue("A1") = Section & Struct iProperties.Value("Project", "Revision Number") = "A" OldPartNumber = iProperties.Value("Project", "Part Number") 'Show user the next row number which is blank MessageBox.Show("Inserting Data on Row " & rowN, "Updating Database...") 'Store Old part Number NewPartNumber = GoExcel.CellValue("B1") 'Update iProperties iProperties.Value("Project", "Part Number") = NewPartNumber Filename = GoExcel.CellValue("B1") & iProperties.Value("Project", "Revision Number")& "_" & iProperties.Value("Project", "Description") iProperties.Value("Summary", "Title") = Filename GoExcel.CellValue("C" & RowN) = GoExcel.CellValue("B1") GoExcel.CellValue("D" & RowN) = iProperties.Value("Project", "Revision Number") GoExcel.CellValue("E" & RowN) = iProperties.Value("Project", "Description") GoExcel.CellValue("F" & RowN) = Filename iProperties.Value("Project", "Designer") = iProperties.Value("Summary", "Author") MessageBox.Show("Your Unique Part Number is " & Filename, "Updating Database...") GoExcel.Save ' 'define the active document oDoc = ThisDoc.Document 'create a file dialog box Dim oFileDlg2 As inventor.FileDialog = Nothing InventorVb.Application.CreateFileDialog(oFileDlg2) 'check file type and set dialog filter If oDoc.DocumentType = kPartDocumentObject Then oFileDlg2.Filter = "Autodesk Inventor Part Files (*.ipt)|*.ipt" Else If oDoc.DocumentType = kAssemblyDocumentObject Then oFileDlg2.Filter = "Autodesk Inventor Assembly Files (*.iam)|*.iam" Else If oDoc.DocumentType = kDrawingDocumentObject Then oFileDlg2.Filter = "Autodesk Inventor Drawing Files (*.idw)|*.idw" End If 'set the directory to open the dialog at oFileDlg2.InitialDirectory = ThisDoc.WorkspacePath() 'set the file name string to use in the input box oFileDlg2.FileName = Filename 'work with an error created by the user backing out of the save oFileDlg2.CancelError = True On Error Resume Next 'specify the file dialog as a save dialog (rather than a open dialog) oFileDlg2.ShowSave() 'Catch an empty String in the imput If Err.Number <> 0 Then MessageBox.Show("No File Saved.", "iLogic: Dialog Canceled") 'Enter Code which removes last entry from Spreadsheet 'GoExcel.Open(Worksheet, Sheetno) For count = RowStart To RowEnd ' If it's blank count it If String.IsNullOrEmpty(GoExcel.CellValue("C" & count)) Then ' Last entry was on bottom row minus 1 rowN = count -1 'Exit For loop Exit For End If Next iProperties.Value("Project", "Part Number") = OldPartNumber iProperties.Value("Summary", "Title") = iProperties.Value("Project", "Description") MessageBox.Show("No File Saved." &vbLf & "Removing Last Entry From Database...") GoExcel.CellValue("C" & RowN) = "" GoExcel.CellValue("D" & RowN) = "" GoExcel.CellValue("E" & RowN) = "" GoExcel.CellValue("F" & RowN) = "" GoExcel.Save ElseIf oFileDlg2.FileName <> "" Then MyFile = oFileDlg2.FileName 'save the file oDoc.SaveAs(MyFile, False) 'True = Save As Copy & False = Save As End If Else 'Else statement for if excel dir(worksheet) = "" MessageBox.Show("Excel Failed to Open." &vbLf & "Ensure Engineering Root is mapped to Z:/", "Error Handler") End If iLogicVb.UpdateWhenDone = True
Dan
