Hi frank,
Here is a variation of what I use. I took some stuff out, so hopefully I didn't miss something that will cause you an error.
I hope this helps.
Curtis
Sub Main
Call CheckFileType()
Call Create_Custom_Params()
'set up sheet metal file
If SharedVariable.Exists("IsSheetMetal") = True Then
If SharedVariable("IsSheetMetal") = True Then
Call SheetMetalSetup()
'clear the arrayList
cParams.Clear
InventorVb.DocumentUpdate()
End Sub
Dim i As Integer
Dim cParams As New ArrayList
Sub CheckFileType()
oDoc = ThisApplication.ActiveEditDocument
If oDoc.DocumentType = kPartDocumentObject Then
'check for Sheet Metal parts
If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
Call SM_Params()
Call Part_Params()
SharedVariable("IsPartFile") = True
Else If oDoc.DocumentType = kDrawingDocumentObject Then
Call Drawing_Params()
Else If oDoc.DocumentType = kAssemblyDocumentObject Then
Call Assembly_Params()
Else
End Sub
Sub SM_Params()
'create array list for sheet metal part files
'Add a line to add to the Parameters to be created/set
'example:
'cParams.add("Parameter Name" & "|" & Parameter Value & "|" kParameter Type)
cParams.add("THICK" & "|" & "1" & "|" & "11272") '11272 = Inches
cParams.add("WIDTH" & "|" & "1" & "|" & "11272") '11272 = Inches
cParams.add("LENGTH" & "|" & "1" & "|" & "11272") '11272 = Inches
cParams.add("G_L" & "|" & "1" & "|" & "11272") '11272 = Inches
cParams.add("PERCENTOFSHEET" & "|" & "1" & "|" & "11272") '11272 = Inches
'kTextUnits = 11346
'kUnitlessUnits = 11265
'kBooleanUnits = 11347
'kAcreAreaUnits = 11301
'kDegreeAngleUnits = 11279
'kFootLengthUnits = 11273
'kInchLengthUnits = 11272
'kLbForceUnits = 11313
End Sub
Sub Part_Params()
'create array list for part files
'example:
End Sub
Sub Drawing_Params()
'create array list for drawing files
'example:
End Sub
Sub Assembly_Params()
'create array list for assembly files
'example:
End Sub
Sub Create_Custom_Params()
'run through the arraylist
If cParams.Count = 0 Then
Return
Dim oDoc As PartDocument
'define customer parameter set
Dim oParams As Parameters
oParams = oDoc.ComponentDefinition.Parameters
Dim oUserParams As UserParameters
oUserParams = oParams.UserParameters
Dim words As String()
For List_Item = 0 To cParams.Count - 1
'split the arraylist value into words using the vertical bar character
words = cParams.Item(List_Item).Split(New Char() {"|"c})
'result:
'words(0) = Parameter Name
'words(1) = Parameter Value
'words(2) = Parameter Units
Dim oValue As Double = words(1)
Dim oUnits As UnitsTypeEnum = words(2) 'k Parameter Type
Try
'Try To read the Parameter
oUserParams(words(0)).Value = oValue
Catch
'Catch Error when Parameter doesn't exist and create it
oUserParams.AddByValue(words(0), oValue , oUnits)
End Try
Dim oParam As Parameter
Dim oFormat As CustomPropertyFormat
oParam = Parameter.Param(words(0))
oParam.ExposedAsProperty = True
oFormat= oParam.CustomPropertyFormat
oFormat.PropertyType=Inventor.CustomPropertyTypeEnum.kTextPropertyType
oFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kThreeDecimalPlacesPrecision
oFormat.ShowUnitsString = False
'kTextUnits = 11346
If words(2) = "11272" Then
oFormat.Units = "in"
Else If words(2) = "11273" Then
oFormat.Units = "ft"
Else
Next
End Sub
Sub SheetMetalSetup()
If words(0) = "WIDTH" Or words(0) = "PERCENTOFSHEET" Or words(0) = "G_L" Then
'MessageBox.Show(oParam.ExposedAsProperty, oParam.Name)
Else
oParam.ExposedAsProperty = False
Next
'set paramter value
Parameter.Param("G_L").Expression = "LENGTH"
Parameter.Param("THICK").Expression = "Thickness"
Dim oDoc As PartDocument 'added 2/17/16
Dim oSMDef As SheetMetalComponentDefinition
'updated 2/17/16
'oSMDef = ThisApplication.ActiveEditDocument.ComponentDefinition
oSMDef = oDoc.ComponentDefinition
'oSMDef.UseSheetMetalStyleThickness = True
Try 'to create flatpattern
If oSMDef.HasFlatPattern = False Then
oSMDef.Unfold
oSMDef.FlatPattern.ExitEdit
Catch 'error when flat can't be created
End Try
'ensure this part has a flat pattern before running rule
Return
Else
iLogicVb.RunExternalRule("WidLen")
End Sub
