Ilogic to place a sketch symbol with field text in it
akaluri
akaluri
Hello ,
I am currently using the following code to place sketch symbol in my drawing. But this doesn't seem to be working for sketch symbol with field text in it (or prompted entry). Do you know how to place such a sketch symbol using ilogic? Thanks in advance!
    Dim oDrawDoc As DrawingDocument
    oDrawDoc = ThisApplication.ActiveDocument
    'create insertion point
    Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
    Dim oInsertionPoint As Point2d
    'define the insert point for the symbol
    oInsertionPoint = oTG.CreatePoint2d(5,5)
'define symbol Definition to use oSymDef= oDrawDoc.SketchedSymbolDefinitions.Item("MYSKETCHSYMBOL") 'Get the current active sheet Dim oCurrentNumber As Sheet oCurrentNumber = oDrawDoc.ActiveSheet 'insert the new symbol oSym = oCurrentNumber.SketchedSymbols.Add(oSymDef,oInsertionPoint,0,1,Nothing)
akaluri
I am able to place the symbol when I insert the following string into the code.
The sketch symbol has 7 field that can be filled. But when I run, the sketch symbol is being placed but not the string values.
    Dim sPromptStrings(6) As String
    sPromptStrings(0) = "123"
    sPromptStrings(1) = "123"
    sPromptStrings(2) = "123"
    sPromptStrings(3) = "123"
    sPromptStrings(4) = "123"
    sPromptStrings(5) = "123"
    sPromptStrings(6) = "123"
    oSym = oCurrentNumber.SketchedSymbols.Add(oSymDef,oInsertionPoint,0,1,sPromptStrings)
chandra.shekar.g
Autodesk Support
Autodesk Support
@akaluri ,
Can you please provide non confidential drawing with sketched symbol to investigate?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
akaluri
@chandra.shekar.g the program seems to be working with the solution I provided. Thanks.
