iLogic to launch Excel file?
What's the best way to get iLogic to launch Excel?
I know I can use
ThisDoc.Launch("path\file.ext")
But, I want to launch an excel file, and have it appear on the proper sheet (set by a parameter).   Is this possible?
MjDeck
Here's sample code to do it.  The GoExcel.Close is required only if you have already used some GoExcel functions in the same rule.
GoExcel.Close
Dim sheetName As String = "Sheet3"
newExcelApp = CreateObject("Excel.Application")
newExcelApp.Visible = True
' Open a file that is in the same directory as this part:
wb = newExcelApp.Workbooks.Open(IO.Path.Combine(ThisDoc.Path, "ExcelSheetList.xlsx"))
wb.Sheets(sheetName).Activate ' Sample code to activate a specific sheet
Mike Deck
Software Developer
Autodesk, Inc.
