Message 1 of 1
iLogic to Insert Sheet Format and Place Part View From Assembly
01:53 PM
I'm trying to write an iLogic rule that when ran will look at the base view assembly placed on a drawing and create a sheet for each part in that assembly and drop a view scaled to the sheet. The additional sheets would be inserted from a custom Sheet Format called "Cut Sheet". This is to shortcut the need to right click and select "New Sheet" for each part and then having to manually open each part and place the view. It will end up saving a significant amount of time.
At some point I will want it to only create sheets for parts in the assembly with a Parameter marked True. But if I can just get the first part for now, it would help a lot.
Thanks.
