iLogic to get from which view the projected view is made and how to do it?
engilic
engilic
Is it possible to get from which view the projected view is made and how to do it?
Thank you
dutt.thakar
@engilic
Is this something you are looking for?
Dim oView As DrawingView = ActiveSheet.View("View Name").View ' Add your view name
MessageBox.Show(oView.ParentView.Name) ' Parent view will only return a value if the view is dependent on something, else it will return nothing.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
engilic
Thank you @dutt.thakar ,
of course it is ParentView.
thank you very much
