ilogic to flip the Rectangular Pattern as PartFeature
mallorn
mallorn
hello,
How to flip the Rectangular Pattern set as a PartFeature?
Dim oDoc As PartDocument = ThisDoc.Document
Dim oCompDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim oOccPat As PartFeature  = oCompDef.Features.Item("Rectangular Pattern1")
Tomasz Malinowski
JelteDeJong
try this:
Dim oRectangularPatternFeature As RectangularPatternFeature = oCompDef.Features.RectangularPatternFeatures.Item("Rectangular Pattern1")
'you can get the first item in the pattern like this
Dim oOccPat = oRectangularPatternFeature.Definition.ParentFeatures.Item(1)
Jelte de Jong
Blog: hjalte.nl - github.com
Curtis_Waguespack
Hi @mallorn ,
If you're asking about flipping the direction of the pattern, you can find and example here:
https://forums.autodesk.com/t5/inventor-customization/changing-circular-pattern-orientation-with-ilo...
Also just as a reminder, you can search and ask programming questions of this type on the Inventor Customization forum :
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
WCrihfield
@mallorn Here's also a simple iLogic example of this
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim oRectPattFeat As RectangularPatternFeature = oDef.Features.RectangularPatternFeatures.Item("Rectangular Pattern1")
If oRectPattFeat.Definition.NaturalXDirection = True Then
	oRectPattFeat.Definition.NaturalXDirection = False
ElseIf oRectPattFeat.Definition.NaturalXDirection = False Then
If oRectPattFeat.Definition.NaturalYDirection = True Then
	oRectPattFeat.Definition.NaturalYDirection = False
ElseIf oRectPattFeat.Definition.NaturalYDirection = False Then
I hope this helps.
If this solves your problem, or answers your questions, please click 'Accept As Solution".
Or, if this helps you reach your goal, please click 'LIKES" 👍.
Here are a few of the ideas I like.
If you agree, please vote for them, so they might get implemented.
  • Options to format contents of MessageBox, InputBox, and InputListBox Click Here
  • Ability to fully constrain and dimension to the edjes of images within drawing title block sketches, SketchedSymbol sketches, other drawing sketches, and assembly sketches Click Here
  • Save section view status in DesignViewRepresentation, so it can be used in drawing view Click Here
  • Add SolidBodies folder to iLogic Rule Editor Model Tab Click Here
  • Convert all views to Raster before autosave stores to 'OldVersions' folder Click Here
Wesley Crihfield
(Not an Autodesk Employee)
