iLogic To Find Grounded and Unresolved Components
Does anyone have a good iLogic script for finding and highlighting unresolved components in an assembly? Would be nice to have a script for finding these components rather than digging through multiple levels of an assembly looking for a "?".
Additionally does anyone have anything for identifying grounded components within an assembly?
Curtis_Waguespack
Hi @Anonymous
Here are a couple of examples.
Note that you can search and ask programming questions of this type on the Inventor Customization forum:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
Find Unresolved components
Sub main
    Dim oFile As Inventor.File
    oFile = ThisApplication.ActiveDocument.File
    Dim oDoc As AssemblyDocument
    oDoc = ThisApplication.ActiveDocument
    Dim oDocDef As AssemblyComponentDefinition
    oDocDef = oDoc.ComponentDefinition
    Call FindUnresolved(oFile, oDoc, oDocDef)
End Sub
Sub FindUnresolved(ByVal oFile As Inventor.File, oDoc As AssemblyDocument, oDocDef As ComponentDefinition)
Dim oSelection As SelectSet
oSelection = oDoc.SelectSet
oSelection.Clear
Dim oCollection As ObjectCollection
oCollection = ThisApplication.TransientObjects.CreateObjectCollection
    Dim oFileDescriptor As FileDescriptor
    For Each oFileDescriptor In oFile.ReferencedFileDescriptors
        If Not oFileDescriptor.ReferenceMissing Then
            If Not oFileDescriptor.ReferencedFileType = FileTypeEnum.kForeignFileType Then
                Call FindUnresolved(oFileDescriptor.ReferencedFile, oDoc, oDocDef)
        Else
	        Dim oOccurrence As ComponentOccurrence
	        For Each oOccurrence In oDocDef.Occurrences.AllLeafOccurrences
	        If oOccurrence.ReferencedDocumentDescriptor.ReferencedFileDescriptor.FullFileName _
				 = oFileDescriptor.FullFileName Then
	       		oCollection.Add(oOccurrence)
	        Next oOccurrence
    Next
	oSelection.SelectMultiple(oCollection)
End Sub
Select grounded components
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oDoc.ComponentDefinition
oSelection.Clear
For Each oOccurrence In oAsmCompDef.Occurrences
   If oOccurrence.Grounded = True Then
Next
