iLogic to 'Enable Row Merge on Part Number Match' in .idw Drawing
I have my ilogic code that can extract the Part List out to a .txt file in Drawing Mode not in Assembly,
before doing that, I need to merge all the same parts, and I have to manually do Enable Row Merge every single time...
I tried imply this code into my ilogic, but it doesn't work, can someone please help me?
Dim oDoc As Document
oDoc = ThisDoc.Document
For each oSubDoc in oDoc.AllReferencedDocuments
Try Dim oCD As AssemblyComponentDefinition
oCD = oDoc.ComponentDefinition oBOM = oCD.BOM
oBOM.SetPartNumberMergeSettings(True)
Catch
End Try
Next
FINET_Laurent
Morning,
oSubDoc is not declared anywhere..
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Tony_Yates
Try this:-
' Get the active application
Dim oInvApp As Application
oInvApp = ThisApplication
' Get the active document
' This code assumes it's an assembly document
Dim oDoc As AssemblyDocument
oDoc = oInvApp.ActiveDocument
' Get the BOM object
Dim oBom As BOM
oBom = oDoc.ComponentDefinition.BOM
'Dim sList() As String
Dim booleanParam As Boolean
' Set the Row Merge Settings
oBom.SetPartNumberMergeSettings(True)'(booleanParam, sKeys)
