Ilogic to do mass drawing export of all drawings related with an assembly
JacobRL4SN
JacobRL4SN
I am trying to write a piece of ilogic that would take an overall assembly open all the drawings for all the subassemblies and parts associated and export them all as a PDF to a specified location on my computer and close the documents as it goes. However, I am completely striking out. Anyone have any ideas on how to fix my code, I am very much new to the ilogic world and any help would be appreciated.
' iLogic code to open and export PDFs for parts and subassemblies of the open assembly
' Create a FolderBrowserDialog to prompt the user for the export location
Dim folderBrowserDialog As New System.Windows.Forms.FolderBrowserDialog()
folderBrowserDialog.Description = "Select a folder to save PDF files"
folderBrowserDialog.ShowNewFolderButton = True
' Show the FolderBrowserDialog
If folderBrowserDialog.ShowDialog() = System.Windows.Forms.DialogResult.OK Then
    ' Get the selected export folder
    Dim exportFolder As String = folderBrowserDialog.SelectedPath
    ' Get the active assembly document
    Dim asmDoc As AssemblyDocument = ThisApplication.ActiveDocument
    ' Iterate through each occurrence in the assembly
    For Each compOccurrence As ComponentOccurrence In asmDoc.ComponentDefinition.Occurrences
        Dim compDoc As Document = compOccurrence.Definition.Document
        ' Check if the component is a part or a subassembly
        If compDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Or compDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
            ' Open the part or subassembly document
            Dim compDocPath As String = compDoc.FullFileName
            Dim compDocObj As Document = ThisApplication.Documents.Open(compDocPath)
            ' Check if there is an associated drawing
            Dim drawingDescriptor As FileDescriptor = compDocObj.File.FileDescriptor
            If drawingDescriptor IsNot Nothing AndAlso drawingDescriptor.FileType = FileTypeEnum.kDrawingFileType Then
                ' Open the drawing document
                Dim drawingDocPath As String = drawingDescriptor.FullFileName
                Dim drawingDocObj As Document = ThisApplication.Documents.Open(drawingDocPath)
                ' Export the drawing as a PDF
                Dim pdfPath As String = System.IO.Path.Combine(exportFolder, compDoc.DisplayName & ".pdf")
                drawingDocObj.SaveAs(pdfPath, True)
                MsgBox("PDF for " & compDoc.DisplayName & " exported successfully.", vbInformation)
                ' Close the drawing document
                drawingDocObj.Close(True)
            Else
                MsgBox("No drawing found for " & compDoc.DisplayName, vbExclamation)
            ' Close the part or subassembly document
            compDocObj.Close(True)
    Next
Else
    ' User canceled the FolderBrowserDialog
    MsgBox("Export canceled by user.", vbInformation)
A.Acheson
Hi @JacobRL4SN
Can you indicate where your having trouble? Please copy the error message on the more info tab and post it here. A note that simply saving as will have likely a low quality result. There is lots of samples on this forum to print to pdf. One such example here
Regards
Alan
