iLogic To Create Custom Parameters That Match User Defined Parameters
fsnyderE8767
fsnyderE8767
I'm not sure if i am going about this the correct way, but what I am trying to do is create a custom TEXT property that matches the value of a user defined property.
Say I have a property called "Force_Extend" and it's values are 4000 lbforce, but I want to make a custom text property without the underscore called "Force Extend."  If I do the following code
iProperties.Value("Custom", "Force Extend") = Parameter("Force_Extend")
 and then open the properties, it created a new property called "Force Extend" but the value is not 4,000 and it is not Text.  The value is a crazy number 1544354.3307086611 and the type is Number.
Is there a way to make the "Force Extend" custom property say 4000 as a Text type?
Michael.Navara
If you want to use iLogic for this, you need to convert internal value to the required units.
'Get parameter value in internal units
' iLogic
'Dim forceExtendValueInDbUnits = Parameter.Param("Force_Extend").Value
' Standard API
Dim part As PartDocument = ThisDoc.Document
Dim forceExtendValueInDbUnits = part.ComponentDefinition.Parameters("Force_Extend").Value
'Convert value to required units. Internal units for force is "kg*cm/s/s"
Dim forceExtendValueInLbforce = ThisDoc.Document.UnitsOfMeasure.ConvertUnits(forceExtendValueInDbUnits, "kg*cm/s/s", "lbforce")
'Use result
Logger.Debug(forceExtendValueInLbforce)
iProperties.Value("Custom", "ForceExtend") = forceExtendValueInLbforce.ToString()
fsnyderE8767
Thanks Michael, that worked great!  I'll be honest, I kind of understand what you did, but where did the kg*cm/s/s come from?  I would like to have this same rule done to convert PSI to text as done with the lbforce but I'm lost on to how you started with those units.
Michael.Navara
This strange units becomes from definition of basic unit for force Newton (N) and units used internally in Inventor.
N = kg * m * s-2 because Inventor uses internal unit for length centimeter, you can construct the internal unit for force as kg * cm * s-2 and because you can't use power in units definition you get kg*cm/s/s.
The same you can do for psi. Pressure is defined as psi = lbforce/in2. In SI units it is Pa = N/m2 => internal units for pressure is kg/cm/s/s.
