iLogic to change the unit precision of all Frame Generator members in Document Settings
jerick.j
jerick.j
I was wondering if anyone could help develop an iLogic script that could:
  1. Change the Linear Dim Display Precision of every member in a frame to "0." instead of the default "3.123". (see attached image)
  2. Change the Base Quantity to the "G_L" parameter (see attached image)
I usually need to go into each individual frame member file and manually change the precision which can be very time consuming when there are a lot of members.
basautomationservices
Hi there, as far as I know the G_L parameter should already be the default Base Quantity for Frame generator items. I also don't know if FG will overwrite the things you edit but, you can change the base quantity like this, once you retrieved the parameter.
oCompDef.BOMQuantity.SetBaseQuantity(BOMQuantityTypeEnum.kParameterBOMQuantity, oUserParam)
The precision and other settings is also changeable. You need to access the CustomPropertyFormat property of the parameter.
Dim f As CustomPropertyFormat = oParam.CustomPropertyFormat
If f.PropertyType <> CustomPropertyTypeEnum.kNumberPropertyType Then f.PropertyType = CustomPropertyTypeEnum.kNumberPropertyType
If f.Precision <> CustomPropertyPrecisionEnum.kZeroDecimalPlacePrecision Then f.Precision = CustomPropertyPrecisionEnum.kZeroDecimalPlacePrecision
If f.ShowUnitsString Then f.ShowUnitsString = False
Contact me for custom app development info@basautomationservices.com. Follow below links to view my Inventor appstore apps.
Free apps: Smart Leader | Part Visibility Utility | Mate Origins
Paid apps: Frame Stiffener Tool | Constrain Plane Toggle | Property Editor Pro
