iLogic to change iProperties of existing virtual component
jamie.lambJXK6F
jamie.lambJXK6F
Hi, I'm trying to write some iLogic that will create a virtual component, and populate its Part Number and Description iProperties to match the parent assembly (the reason I want to do this is not important).  I'd like it to just populate these iProperties if that virtual component already exists. I'm a real novice at this, but have managed to get the following to work by copying snippets of code from elsewhere:
'Create Virtual Component
oOcc = oAsm.ComponentDefinition.Occurrences.AddVirtual("virtualPart", oMatrix)
'edit iProperties
oOcc.Definition.PropertySets.Item(3).Item("Part number").Value = iProperties.Value("Project", "Part Number")
oOcc.Definition.PropertySets.Item(3).Item("Description").Value = iProperties.Value("Project", "Description")
This works great to create the virtual part and populate the iProperties, but if I run it again, it throws an error ("The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))" ) and does not update the iProperties, presumably because "virtualPart" already exists.  How can I get this to update the iProperties if the virtual component has already been created?
Apologies for the simplistic nature of this, like I said, I'm very new to this!
A.Acheson
Hi @jamie.lambJXK6F
You can use a Try Catch statement to catch the error of occurrence allready existing and then reference this occurrence using item by name see help page here
Try
Catch
   oOcc = oAsm.ComponentDefinition.Occurrences.ItemByName("virtualPart")
End Try
Regards
Alan
jamie.lambJXK6F
Hi  @A.Acheson,
Thanks for this. I see the idea, but unfortunately it still doesn't work.  My full code  is as follows:
Dim oAsm As AssemblyDocument = ThisDoc.Document
Dim oMatrix As Matrix = ThisApplication.TransientGeometry.CreateMatrix
Dim oOcc As ComponentOccurrence
Try
Catch
End Try
'edit iProperties
As before, runing this works great if the virtual part has not yet been created, but if it is already existing, I get the error :'The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))".
I think the problem is in the line
 Because when I delete the step to create the virtual part altogether and just use this to try to set oOcc when I have already previously created the virtual component, I get the same error.
I've looked at the help page you linked, thanks for that, but I'm afraid it's a bit above my level of understanding... is there perhaps a simple syntax error I have wrong in that problem line?
guillaume_aubin
Hi @jamie.lambJXK6F
I tested you program and I have come to this conclusion:
You were right it was this line the problem.
The reason is that when added to the assembly, the name of the virtual part is not " virtualPart" as expected, but it become "virtualPart:1". You can verify this with a line like this  :
MessageBox.Show(oAsm.ComponentDefinition.Occurrences.Item(1).Name)
 (Note that the virtualPart must be the only occurence in the assembly to be Item(1) )
J-Camper
@jamie.lambJXK6F,
The DisplayName Can be checked, as that should be the name used to create the virtual part.  here is an example:
Sub Main
	Dim aDoc As AssemblyDocument = TryCast(ThisApplication.ActiveDocument, AssemblyDocument)
	If IsNothing(aDoc) Then Logger.Debug("Not Run In Assembly Document") : Exit Sub
	Dim virtComponentName As String = "virtualPart"
	Dim virtComponentPartNumber As Object = aDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
	Dim virtComponentDescription As Object = aDoc.PropertySets.Item("Design Tracking Properties").Item("Description").Value
	Dim virtComponent As ComponentOccurrence = Nothing
	For Each co As ComponentOccurrence In aDoc.ComponentDefinition.Occurrences.Cast(Of ComponentOccurrence).Where(Function(v) v.Definition.Type.Equals(ObjectTypeEnum.kVirtualComponentDefinitionObject))
		If co.Definition.DisplayName <> virtComponentName Then Continue For
		virtComponent = co
		Exit For
	Next
	If IsNothing(virtComponent)
		virtComponent = aDoc.ComponentDefinition.Occurrences.AddVirtual(virtComponentName, ThisApplication.TransientGeometry.CreateMatrix())
	virtComponent.Definition.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = virtComponentPartNumber
	virtComponent.Definition.PropertySets.Item("Design Tracking Properties").Item("Description").Value = virtComponentDescription
End Sub
Let me know if you have any questions
jamie.lambJXK6F
Amazing, this works perfectly! Thanks @J-Camper
