ilogic to change BOM structure field in document settings - IPT
rzillich
rzillich
Sigh, I feel like this should have been EASY easy, like basic level coding even in a beginner's sense. But here i am, Im trying to get iLogic to change the default bom structure field in the document settings window on an IPT. this is what i have, the 'purchasedComponent' field changes just fine, the BOM structure does nothing at all, no error, no change, nothin'... this is what i have
SyntaxEditor Code Snippet
        Try
                If purchasedComponent = True Then
                        iProperties.Value("Custom", "purchasedComponent") = "P"
                        ThisDoc.Document.ComponentDefinition.BOMStructure = BOMStructureEnum.kPurchasedBOMStructure
                    Else If purchasedComponent = False
                        iProperties.Value("Custom", "purchasedComponent") = "M"
                        ThisDoc.Document.ComponentDefinition.BOMStructure = BOMStructureEnum.kNormalBOMStructure
            Catch
        End Try
philip1009
You forgot to end the second statement with another Then
ElseIf purchasedComponent = False Then
In case you don't know, on the Ribbon, go to Manage > iLogic > Event Triggers, and you can set a trigger to run this rule automatically.
dusan.naus.trz
This works for me. Thank you
ThisApplication.CommandManager.ControlDefinitions.Item("AppUpdateMassPropertiesCmd").Execute
myMass = iProperties.Mass
If ThisDoc.Document.ComponentDefinition.BOMStructure = BOMStructureEnum.kPurchasedBOMStructure Then
iProperties.Value("Custom", "MyMassiProp") = Round(myMass, 3)
philip1009
You can shorten that 3 line if statement into 1 with a little shortcut.  Basically if there's only one line of code between your If and End statements, you can move that line to after the Then statement and remove the End statement afterwards.
If ThisDoc.Document.ComponentDefinition.BOMStructure = BOMStructureEnum.kPurchasedBOMStructure Then iProperties.Value("Custom", "MyMassiProp") = Round(myMass, 3)
