iLogic to change a parameter and save as part
autodesk_siva
autodesk_siva
I have a family of parts in which the length of the part alone varies.
I would like to create all parts by ilogic rather than ipart.
The master model has been created with model parameter as "LENGTH"
Now, I want to write a rule to change the length of master model and save as with new name.
This operation should be repeated for incremental length of the master model.
Can anyone guide me how to do this..
Thanks in advance.
Sivanantham. V
ThomasB44
Hi Siva,
Something like this should help you :
SyntaxEditor Code Snippet
For LENGHT = 1 To 10
    Parameter("LENGHT") = LENGHT
    iProperties.Value("Summary", "Title") = "PART LG " & LENGHT & " mm"
    iProperties.Value("Project", "Part Number") = "PART" & LENGHT
    iProperties.Value("Project", "Description") = "PART" & LENGHT
    Dim Path, PartName, NewFileName As String
    Path = ThisDoc.Path
    PartName = ThisDoc.FileName
    NewFileName = Path & "\" & PartName & " LG " & LENGHT & ".ipt"
    ThisDoc.Document.SaveAs(NewFileName, True)
Next
Check here if you need some code :
 http://forums.autodesk.com/t5/inventor-customization/bd-p/120
Good luck,
Thomas
Mechanical Designer / Inventor Professional 2025
Inventor Professional EESignature
ThomasB44
You should post this here :
Thomas
