iLogic to add a Rule to an event trigger
Message 1 of 1
Many thanks to MechMachineMan & MegaJerk for guidance (and some directly lifted code)
A complete sub, just give it the name of an existing rule and which "EventName" to put it under and Bob, as they say, is your uncle.
Enjoy:
Sub s_SetRuleEvent(RuleName As String, EventName As String)
'EventName *MUST* match one of the cases in the Select Case statement below, otherwise, no joy
'Not tested for any Events besides Material Change, but in theory...
    Dim BaseName As String
    Dim BaseID As Integer
    Dim BaseUse As String
	Dim EndHolder As Integer = 0 'EndHolder will act as the numerical value that will be attached to the end of the property name.
	Dim oCurrentDoc as Object = ThisDoc.Document
	Try
		customIPropSet = oCurrentDoc.PropertySets.Item("iLogicEventsRules")
	Catch
	End Try
	Try
		If customIPropSet Is Nothing Then
			customIPropSet = oCurrentDoc.PropertySets.Item("_iLogicEventsRules")
	Catch
	End Try
	Try
		If customIPropSet.InternalName <> "{2C540830-0723-455E-A8E2-891722EB4C3E}" Then
			Call customIPropSet.Delete
			customIPropSet = oCurrentDoc.PropertySets.Add("iLogicEventsRules", "{2C540830-0723-455E-A8E2-891722EB4C3E}")
	Catch
	End Try
	Try
	Catch
	End Try
	Try
			MsgBox("Unable to create the Event Triggers property for this file!", , "Event Triggers Not Set")
		Exit Sub
	Catch
	End Try
	Select Case EventName
            Case "After Open Document"
                BaseName = "AfterDocOpen"
                BaseID = 400
                BaseUse = "All"
            Case "Close Document"
                BaseName = "DocClose"
                BaseID = 500
                BaseUse = "All"
            Case "Before Save Document"
                BaseName = "BeforeDocSave"
                BaseID = 700
                BaseUse = "All"
            Case "After Save Document"
                BaseName = "AfterDocSave"
                BaseID = 800
                BaseUse = "All"
            Case "Any Model Parameter Change"
                BaseName = "AfterAnyParamChange"
                BaseID = 1000
                BaseUse = "All"
            Case "Part Geometry Change**"
                BaseName = "PartBodyChanged"
                BaseID = 1200
                BaseUse = "Part"
            Case "Material Change**"
                BaseName = "AfterMaterialChange"
                BaseID = 1400
                BaseUse = "Part"
            Case "Drawing View Change***"
                BaseName = "AfterDrawingViewsUpdate"
                BaseID = 1500
                BaseUse = "Drawing"
            Case "iProperty Change"
                BaseName = "AfterAnyiPropertyChange"
                BaseID = 1600
                BaseUse = "All"
            Case "Feature Suppression Change**"
                BaseName = "AfterFeatureSuppressionChange"
                BaseID = 2000
                BaseUse = "Part"
            Case "Component Suppression Change*"
                BaseName = "AfterComponentSuppressionChange*"
                BaseID = 2200
                BaseUse = "Assembly"
            Case "iPart / iAssembly Change Component*"
                BaseName = "AfterComponentReplace"
                BaseID = 2400
            Case "New Document"
                BaseName = "AfterDocNew"
                BaseID = 2600
                BaseUse = "All"
            Case Else
                BaseUse = "None"
                MsgBox ("Trigger Event Error in Selection", , "Trigger Event Selection Error")
                Exit Sub
        End Select
		If customIPropSet.Count > 0 Then
           'We'll make a loop! This will go through each Property (Event Trigger), 1 Property at a time
            For propItemCounter = 1 To customIPropSet.Count Step 1
                Dim megatest As Object
                megatest = customIPropSet.Item(propItemCounter)
                Dim nameTest As String
                nameTest = Left$(customIPropSet.Item(propItemCounter).Name, Len(TriggerPropName))
                Dim idTest As Integer
                If IsNumeric(customIPropSet.Item(propItemCounter).PropId) Then
                    idTest = customIPropSet.Item(propItemCounter).PropId / 100 * 100
                If idTest = BaseID Then
                    'If the property name is equal, then we need to see if the Value of the property (AKA: The Rule Name) is
                    'equal to the new rule that we made previously. If it is, Then we're all done! The trigger already exists!
                    If customIPropSet.Item(propItemCounter).Value = RuleName Then
                        Exit Sub
                    Else
                        If nameTest = TriggerPropName Then
                            'If that isn't the case, it's alright. But, we'll need to get that numerical value from the end of the current Property
                            'because we will need it later to determine which numerical value is needed for the end of our PropertyName.
                            'The below line is simply looking at the last character of the current Property's Name, which should be a number, and making sure that it IS a number
                            If IsNumeric(Right$(customIPropSet.Item(propItemCounter).Name, Len(customIPropSet.Item(propItemCounter).Name) - Len(TriggerPropName))) = True Then
                                'If it is a number, then we need to convert that value (because it's still a String), into an Integer, and set CurrentEnd to equal it.
                                CurrentEnd = Right$(customIPropSet.Item(propItemCounter).Name, Len(customIPropSet.Item(propItemCounter).Name) - Len(TriggerPropName))
                                'We'll also go on and grab the Property ID of the open Property
                                CurrentID = customIPropSet.Item(propItemCounter).PropId
                                'If the CurrentEnd is larger than our EndHolder (which was defined at the beginning of this sub), Then we need our EndHolder to
                                'equal 1 more than what is currently in use. Remember that we can't end up with two 'AfterDocSave0' entries.
                                If CurrentEnd > EndHolder Then
                                    EndHolder = CurrentEnd + 1
                                ElseIf CurrentEnd = EndHolder Then
                                    'However, if CurrentEnd is = to EndHolder, then we'll just add 1 to it.
                                    EndHolder = EndHolder + 1
                                'We do the same thing for the Property ID.
                                If CurrentID > BaseID Then
                                    BaseID = CurrentID + 1
                                ElseIf CurrentID = BaseID Then
                                    BaseID = BaseID + 1
                            Else
                                'If for some reason that last character in the Property Name isn't a numeric value, then we have more work to do...
                                MsgBox ("The end string for Var: CurrentEnd, was not a Numeric Value. If you're reading this, something needs debugging!", , "Error in SetEventProperty Sub")
                                Exit Sub
                        Else
                            CurrentEnd = (customIPropSet.Item(propItemCounter).PropId - BaseID)
                                BaseID = BaseID + 1
                'Now we do this all over again for every other item/property (if there are any) in the list
                'each time checking to see if the Trigger already exists, or incrementing the values of the numeric ending for the PropertyName
                'and PropertyID.
            Next
        'Now that we're done gathering all of the data on the existing Properties / Items, let's add our own to the list.
        'We call up our CustomIPropSet.Add.
        'RuleName will be the name of the rule we made earlier.
        'TriggerPropName & EndHolder equals the BaseID + the numeric value needed to show when it will fire.
        'BaseID is the new PropertyID that is next in line for use by Inventor.
        Dim oProp As Object
		Try
        	customIPropSet.Add(Trim(RuleName), BaseName & EndHolder, BaseID) 'works, with the trim function, maybe forces conversion to string?  There is no difference between the two strings
		Catch ex As exception
			MsgBox(ex.message & vbCrLf & _
				"Rule Name: " & RuleName & vbCrLf & _
				"Base Name: " & BaseName & Endholder & vbCrLf & _
				"BaseID: " & BaseID)
		End Try
End Sub
Replies (0)
