ilogic text - remove character left and sometimes on the right
dusan.naus.trz
Advisor Advisor
dusan.naus.trz
when I use sValue = 12345 result = 11; 22
when I use sValue = 11 result = 12345; 22
How to remove character ";" ? Sometimes the character is on the left and sometimes on the right.
How to get the right result?
iProperties.Value("Custom", "A") = "12345; 11; 22"
'create a String type variable to hold the value of the first iProperty
Dim oA As String oA = iProperties.Value("Custom", "A") 'check to make sure it now contains a value other than "" If oA = "" Then MsgBox("The 'Plant Listing' iProperty was empty.", vbExclamation, "Empty iProperty") Exit Sub End If Dim sValue As String sValue = "12345" 'sValue = "11" If (iProperties.Value("Custom", "A").Contains(sValue)) Then ' MessageBox.Show("Bingo! " & sValue & " is in the list.", "iLogic") s1 = Replace(iProperties.Value("Custom", "A"), sValue, "") MessageBox.Show(s1, "Title") Else MessageBox.Show("Sorry, " & sValue & " is NOT in the list.", "iLogic") End If
dusan.naus.trz
I wanted to keep it simple, I used this.
'sValue = "12345" & ";"
'sValue = "11" & ";"
sValue = "22" & ";"
Only with 22 it didn't work for me, there is no character ";"
Of course I have more numbers.
maybe i could use Else on that left side ";" 22
Does anyone have another idea?
dusan.naus.trz
I simplified the example. I still haven't figured out how to remove the character ";" for number to the left or to the right.
Dim oA As String
If oA = "" Then
	Exit Sub
'sValue = "22" & ";"
myparam = InputBox("12345; 11; 22", "Title", "Default Entry")
sValue = myparam
'MessageBox.Show(Right(sValue ,+1), "Title")
Else
JelteDeJong
I'm not sure what you trying to do. but maybe this might give you some ideas.
Dim values = "12345;11;22"
Dim list = values.Split(";").ToList()
myparam = InputListBox("Select value", list, oA, Title := "Title", ListName := "List")
list.Remove(myparam)
s1 = String.Join(";", list)
MsgBox(s1)
Jelte de Jong
Blog: hjalte.nl - github.com
dusan.naus.trz
Your code is nice, but I can't ToList values. I'm using iProperty and it can't transfer ToList values.
I needed something like this.
I think I made it too complicated.
I don't know if the code can be simplified? What do you think? Can there be another way?
(Just for clarification. This is not related to the code now. "myparam" is only a simplification. It will be filled via select pick, there will be more numbers and they will not be written but the values will be drawn with iProperties)
Dim oA As String
If oA = "" Then
	Exit Sub
sValue = myparam
	If (iProperties.Value("Custom", "A").Contains(" " & sValue & ";")) Then
		s1 = Replace(iProperties.Value("Custom", "A"), " " & sValue & ";", "")
	ElseIf (iProperties.Value("Custom", "A").Contains("; " & sValue)) Then
		s1 = Replace(iProperties.Value("Custom", "A"), "; " & sValue, "")
	ElseIf (iProperties.Value("Custom", "A").Contains(sValue & ";")) Then
		s1 = Replace(iProperties.Value("Custom", "A"), sValue & ";", "")
	Else
		MessageBox.Show("Something went wrong", "Title")
	iProperties.Value("Custom", "A") = s1
Else
dusan.naus.trz
I found that there are a total of 4 conditions. It is strange that there is no easier way to use this possibility of working with numbers and characters.
'iProperties.Value("Custom", "A") = "12345; 11; 22"
Dim oA As String
If oA = "" Then
	Exit Sub
myparam = InputBox("12345; 11; 22 and other numbers", "Title", "Default Entry")
sValue = myparam
	If (iProperties.Value("Custom", "A").Contains(" " & sValue & ";")) Then' 11;
		'		MessageBox.Show("1", "Title")
	ElseIf (iProperties.Value("Custom", "A").Contains("; " & sValue)) Then'; 22
		'		MessageBox.Show("2", "Title")
	ElseIf (iProperties.Value("Custom", "A").Contains(sValue & ";")) Then'12345;
		'		MessageBox.Show("3", "Title")
	ElseIf (iProperties.Value("Custom", "A").Contains(sValue)) Then'12345
		'		MessageBox.Show("4", "Title")
	Else
	'	MessageBox.Show(s1, "Title")
Else
dusan.naus.trz
I am sending the finished result. Just for curiosity.
iLogic Open Top Assemblies and Numbers to Drawing
https://www.youtube.com/watch?v=j4ce8nACd1g&t=368s
