iLogic Sketch Symbol Prompted Entry Help
Vitalla
Message 1 of 1
Vitalla
I have a sketch symbol being used as a nameplate on my drawing. I am currently using iLogic to populate this from an excel file.
An issue arises when I need a second nameplate with different information on the same drawing, the code populates both sketch symbols.
I'm trying, with no luck, to specify the name of the symbol I am trying to fill out so it only populates the desired nameplate and not both.
 'Browse for the Excel file
Dim oFileDlg As inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
On Error Resume Next
 myXLS = iProperties.Value("Custom", "Link")
'look at NamePlate of the spreadsheet
GoExcel.Open(myXLS, "NamePlate")
'define the drawing
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim oPromptEntry
'gather the current sheet name
Dim oCurrentSheet
oCurrentSheet = oDoc.ActiveSheet.Name
Dim oSymbol As SketchedSymbol
Dim oSymbols As SketchedSymbols
For Each oSheet In oDoc.Sheets
  'activate the sheet
  ThisApplication.ActiveDocument.Sheets.Item().Activate
   oSymbols=oSheet.SketchedSymbols
    oTextBoxes=oSymbol.Definition.Sketch.TextBoxes
   For Each oSymbol In oSymbols
    For Each oTextBox In oSymbol.Definition.Sketch.TextBoxes
                'look at the first 100 rows of the Excel file
                'start at row 2, since row 1 contains headings
                For rowCheck = 2 To 100
            'read the value of the column A
                Dim myCell  As String
            myCell = GoExcel.CellValue("A" & rowCheck)
                'compare the titleblock field name to the value in column A
                If myCell = oTextBox.Text Then
                        'get the value from column B
                                oPromptEntry  = GoExcel.CellValue("B" & rowCheck)
                        'set the prompted entry value
                                Call oSymbol.SetPromptResultText(oTextBox, oPromptEntry)
            Next
            Next
    Next
Next
'return to original sheet
ThisApplication.ActiveDocument.Sheets.Item(oCurrentSheet).Activate
'clear the status bar message
ThisApplication.StatusBarText = ""
'Closes the excel sheet
GoExcel.Close
Replies (0)
