iLogic: Shared Function
lantinma
lantinma
Hi All,
I have made a function (SteelProfile( PartName, Profile)) which works fine inside the rule, but if I want to call to this function in other rules it doesn't work. My question is how a share this function so that each rule can call it?
My function:
Function SteelProfile(PartName, Profile)        'Sub function to get dimensions from excel
ExcelFile = "C:\Users\...\SteelProfilesTable.xlsx"
i = GoExcel.FindRow(ExcelFile, "Sheet1", "Name", "=", Profile)
Parameter(PartName, "Parameter_B") = GoExcel.CurrentRowValue("b")
Parameter(PartName, "Parameter_H") = GoExcel.CurrentRowValue("h")
End Function
Main function and calling function
Sub Main()
'Roof Beams SteelProfile("RoofBeam", RoofBeam_profile) 'Calls the function with values
End Sub
 -Leevi
ianteneth
Hi @lantinma,
Maybe this link will help. It discusses how to run other rules inside your rule.
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Inve...
lantinma
Hi @ianteneth
Thanks for quick reply.
I tried following, "Test1" - rule only includes my SteelProfile function:
Sub Main()
iLogicVb.RunRule("Test1")
SteelProfile("RoofBeam", RoofBeam_profile)        'Calls the fuction with set values
End Sub
Inventor gives same error:
"Rule Compile Errors in Test2, in B2026544.iam
Error on Line 6 : 'SteelProfile' is not declared. It may be inaccessible due to its protection level."
Should I next try to make a macro and run it through Run.Macro command?
