iLogic setting dimensions driven or not
I'm trying to switch between two sets of dimensions being driven or not by using iLogic, but I'm having a bit of a weird issue.
One of the dimensions I named "leaningAngle", and the code looks like this:
SyntaxEditor Code Snippet
Dim oDoc as PartDocument
oDoc = ThisDoc.Document
Dim oSketch1 As Sketch
oSketch1 = oDoc.ComponentDefinition.Sketches.Item("Sketch1")
If choice = "Choice1" Then
    oSketch1.DimensionConstraints.Item(leaningAngle).Driven = False
ElseIf choice = "Choice2" Then
    oSketch1.DimensionConstraints.Item(leaningAngle).Driven = True
The weird thing to me about this is that when I change the choice variable to trigger the if statements, its not leaningAngle that changes to driven (or not), but another dimension in the same sketch thats called "d87" and is a hole diameter. So I'm thinking that I need another reference to the leaningAngle dimension, as the name doesn't seem to work, but how do I do that?
dean.morrison
I believe if you reference something by name it must be within "" just like when you reference sketch1 earlier in your code..
oSketch1.DimensionConstraints.Item("leaningAngle").Driven = True
I hope this fixes your issue.
Dean.
It doesn't seem to work that way, I get an error:
Error in rule: DrivenTest, in document: test.ipt
Conversion from string "leaningAngle" to type 'Integer' is not valid.
The code looks just like in my first post, just with "" around leaningAngle.
Sschram
Take off the "" around the parameter you're trying to use.
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 995 StartFragment: 314 EndFragment: 963 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
oSketch2.DimensionConstraints.Item(WeldCapLength).Driven = True
rjay75
oSketch1.DimensionConstraints.Item(?) requires an integer representing the index of the dimension. That could change as dimensions are added or removed from the sketch. So you could search for the dimension then modifiy it.
'Loop through dimensions looking for the one named leaningAngle
For Each cDim as DimensionConstraint In oSketch1.DimensionConstraints
   If cDim.Parameter.Name = "leaningAngle" Then
         cDim.Driven = False
         cDim.Driven = True
     'Dimension changed stop looping
     Exit For
Next
In your previous attempt it was looking up value of leaningAngle and using that to pick the dimension at the index of that value in the DimensionConstraints.
