iLogic Set dimension to Layer "By Standard"
MairA_DUKA
Message 1 of 9
MairA_DUKA
Hello
In an Inventor-Drawing after Stile-Editor-Update some dimensions are not on the correct Layer.
I want to set all green dimensions on the right Layer.
If I make it manually, I go to select the Layer "By Standard" (in german like "Nach Norm") ...
and after selection the dimension is on the right Layer.
In this case "Nach Norm (DIMENSION)" ==> In English "By Standard (DIMENSION)"
I have written this iLogic-Rule:
Dim oDoc As DrawingDocument
	oDoc = ThisDoc.Document
	If (oDoc.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject) Then
		If (oDoc.DisplayName = "Symbole.idw") Then
			Exit Sub
		Dim oSheet As Sheet = oDoc.ActiveSheet
		Dim oLayer As Layer = oDoc.StylesManager.Layers.Item("DIMENSION")
		Dim oDim As GeneralDimension
		Dim Count As Integer = 0
		For Each oDim In oSheet.DrawingDimensions
			Count = Count + 1
			If (oDim.Layer.Name <> "DIMENSION") Then
				MessageBox.Show(oDim.Layer.Name)
				oDim.Layer = oLayer
		Next
		MessageBox.Show(Count)
I will get this result:
The result for me is not 100% correct, because I want set it to "By Standard (DIMENSION)".
How can I get my wanted result?
Many thanks for your answers.
Replies (8)
Message 2 of 9
tfrohe_LSI
@MairA_DUKA
You should be able to set the Layer to Nothing to have it return the the "By Standard" choice
oDim.Layer = Nothing
Message 3 of 9
engilic
Hi @MairA_DUKA and @tfrohe_LSI ,
this is great solution for Layers.
you are my last hope to make same thing for dimension Style
oDim.Style = Nothing
doesn’t work, or I am doing something wrong
please do you know how to set dimension Style to be By Standard?
tried everything, searched everywhere, posted twice in the forum, nothing
maybe not possible
thx
Message 4 of 9
MairA_DUKA
Hello
You must use this code:
Break
		Count += 1
'			MessageBox.Show(oDim.Layer.Name)
	Next
Message 5 of 9
engilic
thank you @MairA_DUKA ,
As I said, this works for Layers but not for Styles.
Any solution for Styles?
Message 6 of 9
MairA_DUKA
Hello
I can help you with this code.
It sets the style to an other style, but not to "By Standard".
Break
	Dim oNewStyle As DimensionStyle = oDoc.StylesManager.DimensionStyles.Item("Bemaßung (WEC)")
		Count += 1
		If (oDim.Style.Name <> "Bemaßung (WEC)") Then
'			MessageBox.Show(oDim.Style.Name)
			oDim.Style = oNewStyle
	Next
Message 7 of 9
engilic
Thank you @MairA_DUKA ,
You really wanna help but I need to set it to "By standard" not to a particular standard.
I have the code to set it to a particular one but do not need that.
It seems no one knows or it cannot be done, and I really need it.
Thank you for your time.
Message 8 of 9
MairA_DUKA
Hi
I've tried all the options I know, but none of them worked.
Solution 1:
If you have only some dimensions you can select it all in one time and change manually the style to "By standard".
Solution 2:
With your Autodesk-Account you can open a support case directly to Autodesk.
In my experience, they will help you quickly and can give you an answer if it is possible to set the dimensionstyle to "By standard" with iLogic.
Message 9 of 9
engilic
I like option 2.
Will try to open a support case, if do not know how will ask you for help.
You helped a lot, I just thought its game over and I need to give up from that code, you gave me a hope and at the end that might be the crucial thing.
thank you very much
