iLogic - Set break view operation
alysonrssl
alysonrssl
Hi everyone,
I'm not sure that my approach is the good one but I'm trying to get 2D point from a WorkPlane to create a break view operation. The length of my shaft can change but I always want the break view to be setted at the same part of the shaft (see image attached), that's why I've created 2 workplanes to set an upper point of that part and a below point but that doesn't seems to work, maybe there is another way to do it?
Thanks in advance,
	Dim startWP As WorkPoint = asmCompDef.WorkPoints.Item("WorkPoint_Start")
	Dim endWP As WorkPoint = asmCompDef.WorkPoints.Item("WorkPoint_End")
	Dim xCoordStart, yCoordStart, zCoordStart As Double
	zCoordStart = startWP.Point.Z
	Dim xCoordEnd, yCoordEnd, zCoordEnd As Double
	zCoordEnd = startWP.Point.Z
	If (modelLength < 500) Then Return
	Dim startPoint1 As Point2d = oTG.CreatePoint2d(frontView.Center.X, zCoordStart + 10)
	Dim endPoint1 As Point2d = oTG.CreatePoint2d(frontView.Center.X, zCoordEnd - 10)
	Dim startPoint2 As Point2d = frontView.DrawingViewToSheetSpace(startPoint1)
	Dim endPoint2 As Point2d = frontView.DrawingViewToSheetSpace(endPoint1)
	frontView.BreakOperations.Add(BreakOrientationEnum.kVerticalBreakOrientation, startPoint2, endPoint2, BreakStyleEnum.kStructuralBreakStyle, 8, 1)
Michael.Navara
In my opinion (without testing) it is because you use workpoint 3d model coordinates in drawing 2d context.
You need to calculate coordinates correctly
3d Model -> DrawingView -> Sheet
